Find Area of flattened gold with limited info.
  • Thread starter Thread starter Kaleb
    Area Gold
To find the area of a flattened gold leaf with a mass of 1.708 g and a thickness of 6.811 μm, the volume is calculated using the formula V = M/D, yielding a volume of 0.088 cm³. The area is then determined by rearranging the volume formula to A = V/H, where H is the thickness converted to centimeters. An initial error in converting micrometers to centimeters was identified, which led to an incorrect area calculation. After correcting the conversion, the area was recalculated to be 1.29e-3 m². The discussion highlights the importance of accurate unit conversions in solving volume and area problems.
Kaleb
Gold, which has a density of 19.32 g/cm3, is the most ductile metal and can be pressed into a thin leaf or drawn out into a long fiber. (a) If a sample of gold with a mass of 1.708 g, is pressed into a leaf of 6.811 μm thickness, what is the area (in m2) of the leaf? (b) If, instead, the gold is drawn out into a cylindrical fiber of radius 2.100 μm, what is the length (in m) of the fiber?
D = M/V
V = LxWxH(thickness)
So I have been working on this for quite a while now. Here is my attempt:
I first solved D=M/V for V: V=M/D
Then I plugged 1.708g/19.32g/cm^3 to find my volume of .088cm^3
Then using Volume = L x W x H(thickness) I plugged in for volume and height and solved the equation.
When I converted micrometers to centimeters my result was 6.811e-3cm.
So (.088cm^3)/.006811cm = L x W (Area).
After I found the area in cm^2 which the above result yields, I converted to meters^2 and got an answer of 1.29e-3m^2.
It says it is wrong, where did I go wrong?
Your conversion for the thickness is wrong.
1 um is 10^-3mm so 10^-4cm
Alright thanks. That made all the difference, problem solved.
20K
