Find Coeff. of Static Friction of Car on Track
To find the coefficient of static friction for a car on a circular track, the problem involves calculating the velocity at which the car skids off after accelerating uniformly. The car travels 0.2 of the way around a 5m radius track with a tangential acceleration of 1.7m/s². The equations of motion and forces are applied, leading to the relationship between centripetal force and frictional force. The initial calculations yield a coefficient of static friction around 0.436, but errors in computation or assumptions may lead to incorrect results. Further clarification or alternative methods may be needed to resolve discrepancies in the calculations.
wmrunner24
A car traveling on a flat circular track of radius 5m accelerates uniformly from rest with a tangential acceleration of 1.7m/s^2. The car makes it 0.2 of the way around the track before skidding off. Acceleration of gravity=9.8m/s^s.
What is the coefficient of static friction between the car and the track?
Fc=V^2m/r
F=ma
So I tried this:
Fc=Ff
V^2m/r=\mumg
v^2/gr=\mu
To determine the velocity at which the car slips, I said V^2=2ax, where x is 2\pir/5.
So I get 4\pia/5g=\mu
It's not correct. Why is that?
Nice solution. I get 0.436, but I'm prone to calculation errors.
The online homework system marks it wrong. I can't explain it. Is there another way to do this?
