Find the amount of work done against gravity in moving a 150kg rocket
The discussion centers on calculating the work done against gravity when moving a 150kg rocket. The initial energy at Earth's surface is calculated as -0.9 x 10^10 J, while the energy at the orbit radius is -3.4 x 10^9 J, leading to a total work done of 5600 x 10^6 J. The textbook answer of 6 x 10^5 J is questioned, suggesting a possible error in the textbook. Participants confirm the calculations are correct, indicating the textbook may contain a typo. The conclusion affirms the accuracy of the user's calculations.
sdfsfasdfasf
Find the amount of work done against gravity in moving a 150kg rocket from the surface of the Earth to 18000 km above the center of the Earth.
E = -Gmm/r
I started by calculating the energy at the Earths surface, which is just -G(150)(6 x 10^24)/(6400 x 10^3) = -0.9 x 10^10, and calculating the energy at the orbit radius, E = -G(150)(6 x 10^24)/(18000 x 10^3) = -3.4 x 10^9, then doing some subtraction we have -3.4 x 10^9 - (-0.9 x 10^10) = 5600 x 10^6 J. The answer provided in my textbook is 6 x 10^5 J which is clearly not what I got. Any tips?
sdfsfasdfasf said:
Any tips?
Get a better textbook?
Possible typo in the textbook. The answers section.
So my answer is correct?
Yes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
