Find the Focal Length Of a lens
The discussion focuses on finding the focal length of a converging lens based on the distances of an object and the resulting images. The initial setup involves using the lens formula, but participants emphasize the importance of correctly applying parentheses in the equations to avoid mistakes. There is confusion regarding the calculation of the image distance (di) and the need for careful algebraic manipulation. Participants clarify that the correct approach involves rearranging the equation and combining fractions properly. Ultimately, the correct focal length can be determined once the image distance is accurately calculated.
AyooNisto
When an object is placed 69.0cm from a certain converging lens, it forms a real image. When the object is moved to 39.0cm from the lens, the image moves 19.0cm farther from the lens.
Find the focal length of this lens.
1/do + 1/di = 1/f
1/69.0cm + 1/di = 1/f
1/39.0cm + 1/di + 19cm = 1/f
1/69.0cm + 1/di = 1/39.0cm + 1/di + 19cm
which gives di = 20cm
1/69.0 cm + 1/20.0 cm = 1/f
f = 15.5? this is not the right answer though, where am i going wrong?
Parentheses need to be used here: 1/(di + 19cm)
Likewise here.
The algebra is a little tedious, so you will need to be careful soving for di.
Even with the parenthesis in the equations wouldn't di still be 20, 39-19 is 20 either way
Likewise here.
The equation is
##\frac{1}{69} + \frac{1}{d_i} = \frac{1}{39} + \frac{1}{d_i+19}##
Do you see why you can't simply subtract the 39 and 19?
not really I am having a little trouble understanding this problem
TSny said:
The equation is
There are sevaral approaches to solving this equation for ##d_i##.
You might start by rearrainging the equation so that the two terms containing ##d_i## are on the left side and the two fractions without the unknown are on the right.
okay so i have
1/di - 1/di + 19 = 1/39 - 1/69
di + 19/di = 69/39
39di + 741 = 69di
741 = 30di
24.7 = di...is this correct?
AyooNisto said:
okay so i have
You continue to ignore the required parentheses !
Your equation:
1/di - 1/di + 19 = 1/39 - 1/69​
should be:
1/di - 1/(di + 19) = 1/39 - 1/69​
The next step is wrong.
di + 19/di = 69/39
So what follows that is pointless.
What is the common denominator for ##\displaystyle\ \frac{1}{d_i}-\frac{1}{d_i+19}\ ? ##
What is the smallest common denominator for ##\displaystyle\ \frac{1}{39}-\frac{1}{69}\ ? ##
my apologies for ignoring the parenthesis again, i believe the common denominators are
di2+19di and 897
so then it would be 19/di2+19di = 36/897
which would give you di equal .0401337793
1/.0401337793 = 24.91666667
Your equation:
should be:
So what follows that is pointless.What is the common denominator for ##\displaystyle\ \frac{1}{d_i}-\frac{1}{d_i+19}\ ? ##
Can you combine ##\displaystyle\ \frac{1}{d_i}-\frac{1}{d_i+19}## to make one fraction?
i believe i did that in the post above it gives you 19/di2 + 19di. is this wrong?
Oh, I didn't see it! Yes, that's right if you include the parentheses!:
19/(di2 + 19di)
[EDIT:The 36/897 is incorrect.]
okay how is the 36/897 wrong? The first number that 39 and 69 go into evenly is 897. 13*23 and 69*13 is 897. which would igve you 23/897 and 13/897
19/(di2 + 19di)
Yes, but remember that you are subtracting the fractions.
Ohh okay so it would be 19/(di2 + 19di) = 10/897
Yes, that's correct.
  • · Replies 19 ·
