Find the Force applied to a rock by a slingshot
To find the average force applied to a 50-gram rock launched by a slingshot at 24 m/s after being stretched 0.4 meters, the conservation of energy principle is used. The spring constant (k) was initially calculated incorrectly, leading to confusion over the correct average force. The correct formula for the force of a spring is F = kx, which was applied after determining k. The discussion highlights the distinction between calculating average force over distance versus time, suggesting that the average force sought is likely over distance. Ultimately, clarification on the calculations and formulas is necessary to align with the expected answer of 36N.
jesse james
A sling shot can launch a 50gram rock at a speed of 24m/s if it is stretched .4meters before release. Find the average force applied to the rock
Spring force = 1/2*k*x^2
1/2kx^2 = 1/2mv^2
tried to solve for K using 1/2kx^2=1/2mv^2 <-- someone told me to use this formula i don't know if its right
k=180
put that in the formula for spring force Fs=1/2kx^2
gave me the answer of 14.4N
however the correct answer should be 36N
No, that's the PE stored in the spring. The force at extension x is kx.
That formula is correct. It expresses the conservation of energy in this scenario.
Having found k, you then know the force at any particular extension.
But I have a problem with the question. Is the average force the average over distance or the average over time? This will yield two different answers.
For average over distance, use energy again. The energy imparted is -∫F(x).dx; if the average over distance is Fd then -∫F(x).dx = -∫Fd.dx. For average over time, use momentum. The momentum imparted is ∫F(t).dt; if the average over time is Ft then ∫F(t).dt = ∫Ft.dt.
Nice thanks for your reply...
so I was using the wrong formula for the force of the spring once i found K...so I found K the same way as before
then instead of using the formula for Pe of the spring I used hookes formula for the force of a spring which was force=Kx
that gave me the answer of 72 which is exactly double the answer that the teacher wants ...so am i missing a 1/2 in a formula somewhere??..
im not sure if its average over distance or average over time...I am still new at physics and get confused by some of the signs and formulas.
Looks like it must be average over distance that's wanted. How did you calculate the 72? Isn't that the force when at extension 0.4m?
