- 15,830
- 8,987
That's what I assumed. I got an answer for the angle which is probably correct.haruspex said:So assume fully inelastic.
What would be the final answer?kuruman said:That's what I assumed. I got an answer for the angle which is probably correct.
Pls. Help me with this one, what would be the final answers?kuruman said:That's what I assumed. I got an answer for the angle which is probably correct.
Can you explain me how did you arrive with your answer? With complte solution so that i can understand how, plskuruman said:That's what I assumed. I got an answer for the angle which is probably correct.
no, i’m asking for your help so that i can understand completely… however, i can Only comprehend it further if you can provide solutions in order to arrive with the correct answers. By providing the solutions in getting the answers will help me to understand more quicklymalawi_glenn said:Look i know you only want the correct answer and move on. But that is not how we operate on this forum
So pls, provide your solutions, even without the correct answers so that i can practice computing it on my ownkuruman said:That's what I assumed. I got an answer for the angle which is probably correct.
That's all very nice but I think there is something we misunderstood in the problem statement, I refuse to believe that an introductory high school problem (I suspect that the OP is a high school student) has such a complex treatment.kuruman said:So far you have only calculated the speed of ball 1 just before the collision. After the collision, ball 1 will have a velocity that in general can be written as ##\mathbf{v'}_1=v'_{1x}\mathbf{\hat x}+v'_{1y}\mathbf{\hat y}##. The secondary ball can only move in the horizontal direction and will have velocity ##\mathbf{v'}_2=v'_{2x}\mathbf{\hat x}##. Momentum is conserved in the horizontal direction and you can write an expression for that. That's equation 1.
Now here comes the tricky part. The primary ball delivers an impulse only in the center-to-center direction. You need to write an expression for the impulse as the change in momentum of the primary ball and set its component tangent to the surface equal to zero. This will give you an expression relating the three primed components of the velocities. That's equation 2. For this step, it would help if you wrote the normal to the surface ##\mathbf{\hat n}## and the tangent to the surface ##\mathbf{\hat t}## at the point of contact in terms of ##\mathbf{\hat x}## and ##\mathbf{\hat y}.##
Finally, you need to write the energy conservation equation which is equation 3. You have 3 equations and three unknowns which you can solve.
That's what I did and I got an answer. I am not sure that this is what you teacher wants you to do.
I did it a slightly different way. I let J be the impulse between the balls and resolved that into horizontal and vertical. The horizontal component relates to both the subsequent horizontal velocity of each and to the change in vertical velocity of the free ball. Then I used those equations to eliminate J.kuruman said:So far you have only calculated the speed of ball 1 just before the collision. After the collision, ball 1 will have a velocity that in general can be written as ##\mathbf{v'}_1=v'_{1x}\mathbf{\hat x}+v'_{1y}\mathbf{\hat y}##. The secondary ball can only move in the horizontal direction and will have velocity ##\mathbf{v'}_2=v'_{2x}\mathbf{\hat x}##. Momentum is conserved in the horizontal direction and you can write an expression for that. That's equation 1.
I agree with you, hence my last sentence in post #57.Delta2 said:That's all very nice but I think there is something we misunderstood in the problem statement, I refuse to believe that an introductory high school problem (I suspect that the OP is a high school student) has such a complex treatment.
There is a smilar problem in one of my high school books (but not the one I use for class) where it says nothing about the radii of the balls and is indeed treated as a 1-dimensional problem in my "teachers guide". But, something regarding the chord is mentioned in the problem statement. That is why I was so inclined on that track at first.Delta2 said:That's all very nice but I think there is something we misunderstood in the problem statement, I refuse to believe that an introductory high school problem (I suspect that the OP is a high school student) has such a complex treatment.
Hmm, I wonder what exactly is mentioned about the cord that allow us to treat this as a 1-d problem.malawi_glenn said:There is a smilar problem in one of my high school books (but not the one I use for class) where it says nothing about the radii of the balls and is indeed treated as a 1-dimensional problem in my "teachers guide". But, something regarding the chord is mentioned in the problem statement. That is why I was so inclined on that track at first.
Whatever component of velocity the secondary ball had along the collision line (line of centres per Kuruman's diagram above) is lost. The ball retains the other component perpendicular to that.kuruman said:Why point masses?
Here is the diagram at the time of the collision assuming that the balls have the same radius ##R##. It seems to me that the momentum of the two-ball system is not conserved in the vertical direction because the string constrains part of the system from moving in that direction. Assuming that there is no friction while the balls are in contact, the top ball delivers an impulse directed along the center-to-center direction which can be calculated from the geometry.
Why?neilparker62 said:Whatever component of velocity the secondary ball had along the collision line (line of centres per Kuruman's diagram above) is lost.
In essence because when equal masses collide elastically (assume one is initially stationary), momentum along the line of collision is completely transferred. That is why the post collision trajectories of two equal masses are at right angles. (although in this case the motion of the primary mass is constrained by the string).haruspex said:Why?
You can't treat it as two separate events: the collision of the balls and the impulse from the string. It all happens at once, and I would expect some of the string's impulse to feed back into the rebound of the falling ball. In effect, the hanging ball has greater inertia.neilparker62 said:In essence because when equal masses collide elastically (assume one is initially stationary), momentum along the line of collision is completely transferred. That is why the post collision trajectories of two equal masses are at right angles. (although in this case the motion of the primary mass is constrained by the string).
In detail I would need to blow own trumpetand refer you to my Insights article:![]()
https://www.physicsforums.com/insig...-to-solving-2-dimensional-elastic-collisions/
Well I thought about exactly that. And came to the conclusion that if the string has "negligible" mass and is perfectly elastic, the implication is that the instantaneous collision is only between the two balls. The primary ball moves 'out of the way' before any of the string's impulse can 'feed back' to the secondary ball. Otherwise as you've pointed out, we start needing information about the string's spring constant and its tensile strength.haruspex said:You can't treat it as two separate events: the collision of the balls and the impulse from the string. It all happens at once, and I would expect some of the string's impulse to feed back into the rebound of the falling ball. In effect, the hanging ball has greater inertia.
Don't confuse elasticity and extensibility.neilparker62 said:if the string has "negligible" mass and is perfectly elastic, the implication is that the instantaneous collision is only between the two balls
Good point. And that does validate my simulation, more or less.neilparker62 said:Case 1 limiting value would be 30∘ below the horizontal as per physics of an oblique elastic collision between 2 equal masses.
Unfortunately the simulation breaks down there. In a simple simulation of SHM, there's a tendency for the energy to grow exponentially. There are probably some standard tricks for taming this, but I haven't managed to find one.neilparker62 said:could you perhaps set the string's spring constant to 100 times that of ball pair system ?
Having managed to tame the simulation somewhat (by taking any three consecutive values of a position or velocity coordinate to follow a quadratic) I am satisfied that when the string's spring constant is much the greater the suspended ball does not leave with any significant vertical velocity.haruspex said:Fwiw, I have now simulated it, ignoring gravity.
For some arbitrary choices of initial ball speed, mass, etc.:
- With the string having a tenth the spring constant of the ball pair, the left hand ball loses contact with a trajectory of 30.6o below the horizontal.
- With the ball pair and string having the same spring constant, the trajectory is 21.5o below the horizontal.
- With the string having ten times the constant, the trajectory is 13.1o above the horizontal.
So as I surmised, if all is elastic, the relative spring constants are crucial.
Edit: although I intended to ignore gravity, I made the mistake of taking the string as always in tension. I need to allow it to go slack. So ignore the above results.
I would say it’s identical. In principle, the table surface has some elasticity and that would behave just the same as the string in the original.neilparker62 said:Just wondering if this situation is the same as if a ball were dropped onto a 60 degree wedge on a smooth frictionless table ? The wedge has the same mass as the ball and there is no 'slippage' on impact. Collision is elastic.
