Find the period of oscillation of a bead on a cycloid string
The discussion focuses on finding the period of oscillation for a bead on a cycloid string, using the equations of motion derived via Lagrange's method. The equation of motion is established as \ddot{u} + \frac{g}{4a}u = 0, where u = cos(\frac{\theta}{2}). The period of oscillation is suggested to be T = 2π√(4a/g), but confusion arises regarding the correct application of the equations and the factor of 4. Participants emphasize the importance of using the chain rule correctly to relate angular velocity and the second derivative of u. Ultimately, the correct period is confirmed as T = 2π√(a/g), clarifying the initial misunderstanding.
jimz
Find the period of oscillation of a bead on a cycloid string. If it matters, the original equations of the cycloid were
x=a(\theta-sin\theta) and y=a(1+cos\theta)
This is a small part of a larger problem... I found the equation of motion of a bead on a cycloid to be:
\ddot{u}+\frac{g}{4a}u=0
where u=cos(\frac{\theta}{2})
using Lagrange which is correct.
I think I recall period being:
T=\frac{2\pi}{\omega}
also \omega=\frac{\dot{v}}{r}
Not really sure. All I can do is:
\ddot{u}=-\frac{1}{4}cos(\frac{\theta}{2})
and then I don't know what to do.
Any help is greatly appreciated. I even know the answer but can't see how to get there, so obviously this one must be embarrassingly easy.
T=2\pi\sqrt{\frac{4a}{g}}
In the problem u cannot by simply cos(θ/2). Check this.
I'm sure that the equation of motion is correct. It's long and uses some tricky trig identities, but more importantly it matches the answer as given.
In any event, it's the period of oscillation part I do not understand.
OK.
Now u = cos(θ/2)
By using the chain rule
du/dt = (du/dθ)(dθ/dt) = ω[-1/2*sin(θ/2)]
Similarly d^2u/dt^2 = ω^2[-1/4cosθ/2] = -1/4*ω^2*u
Substitute in the first equation and find T.
Thanks! I forgot that dθ/dt is ω and it's the chain rule twice. So close, but why am I off...
-\frac{1}{4}\omega^2u+\frac{g}{4a}u=0
\frac{1}{4}\omega^2=\frac{g}{4a}
\omega=\sqrt{\frac{g}{a}
T=\frac{2\pi}{\omega}=2\pi\sqrt{\frac{a}{g}
Still can't see what I did wrong... how does the 4a not become a?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
