- #36
- 21,678
- 12,869
You also do not need to solve for ##\theta##. Just looking at the total energy expression (expanded for small oscillations) will give you the frequency directly when comparing to the harmonic oscillator energy.
I don't know about CoM frame. So I think I'm going to expand it for small oscillations. I think I should read about oscillations, then try to solve ...Orodruin said:You also do not need to solve for ##\theta##. Just looking at the total energy expression (expanded for small oscillations) will give you the frequency directly when comparing to the harmonic oscillator energy.
This should perhaps be your first step when trying to solve a problem regarding oscillations…MatinSAR said:I think I should read about oscillations, then try to solve ...
I thought that I can find equation of motion without knowing g much about oscillations because this assignment is related to lagrangian mechanics. And I read lagrangian mechanics, not oscillations. Thanks for your help anyway. I will try again after reviewing about oscillations ...Orodruin said:This should perhaps be your first step when trying to solve a problem regarding oscillations…
Thanks a lot for your help ...Steve4Physics said:@MatinSAR, I'm jumping into the thread a bit late in the day, but would like to add this…
Do you mean that I can substitute ##\sin \theta \approx \theta## and ##\cos \theta \approx 1## into the Euler-Lagrange equations to find ##x(t)## and ##\theta (t)##? These approximations were stated in the question, but I wasn’t sure at which part I could use them.Steve4Physics said:Then, for ##\theta \ll 1##, you can use ##\sin \theta \approx \theta## to get rid of ##\sin##. It may be OK to use ##\cos \theta \approx 1## rather than ##\cos \theta \approx 1 - \frac{\theta^2}2## but that could be contentious.
Well, that's what I'd do!MatinSAR said:Do you mean that I can substitute ##\sin \theta \approx \theta## and ##\cos \theta \approx 1## into the Euler-Lagrange equations to find ##x(t)## and ##\theta (t)##?
That suggests you are expected to use them (where appropriate).MatinSAR said:These approximations were stated in the question,
Best not to use them early on, or you can lose information, notably when differentiating. But now you have the final 'exact' equations (in Post #40) it looks like a good time to make any valid approximations.MatinSAR said:but I wasn’t sure at which part I could use them.
If the problem tells you to explicitly use the small angle approximation ##\cos \theta \approx 1 ##, then I think you must use it?MatinSAR said:These approximations were stated in the question, but I wasn’t sure at which part I could use them.
As I said early on:erobz said:I thought your question was when you could use a small angle approximation, and I think everyone @kuruman, @Orodruin were expecting ##\cos \theta \approx 1 - \frac{\theta^2}{2} ## as the approximation when it was said it shouldn't matter whether it was used before or after the application of the Lagrangian.
If you want to end up with a linearized equation of motion you must keep the quadratic terms in the Lagrangian as those are exactly the terms that give you linear terms in thd eom.Orodruin said:Yes, you can expand the Lagrangian for small ##\theta## and then apply the EL equation, but if you want linear EoMs, you need to expand to second order in ##\theta##.
Yeah, I meant everyone except Matin thought… turning cosine into 1 before the application of the derivative seems obviously problematic. When I said "I think everyone"-and listed you in there, it was intended to be a quiet nod to the OP they should be more clear about the required approximation. I certainly wasn't underestimating anyone's understanding of the problem (if anyone doesn't understand its me), sorry if it came off that way.Orodruin said:As I said early on:
Well, are you still on the fence about it?MatinSAR said:I am trying to understand.
I have two equations which were mentioned in post #40. As I understand I can't directly use approximations.erobz said:Well, are you still on the fence about it?
The two equations you have after you apply the partial derivatives ( Euler-Lagrange Equations) are exact. You can apply the approximation ## \cos \theta \approx 1 ## to those. What you can't do is apply that approximation of ## \cos \theta \approx 1## to the original Lagrangian ( i.e. the equation you begin with ##L = T - U##).MatinSAR said:I have two equations which were mentioned in post #40. As I understand I can't directly use approximations.
Everything was mentioned in original post except the approximations of ##\cos \theta =1## and ##\sin \theta =\theta##. I am sorry that I didn't mention them.Steve4Physics said:It would have been helpful (and could still be helpful) if you posted the complete question so we had all relevant information!
Thanks for your time @Steve4Physics ...Steve4Physics said:But now you have the final 'exact' equations (in Post #40) it looks like a good time to make any valid approximations.
(By the way, I'm assuming that you are required to solve the problem with a simple/direct Lagrangian approach using ##x## and ##\theta##. So you are not expected to use any of the alternative approaches others have suggested. )
This is what I wanted to do. I am going to try ... Thanks again.erobz said:The two equations you have after you apply the partial derivatives are exact. You can apply the approximation ## \cos \theta \approx 1 ## to those. What you can't do is apply that approximation of ## \cos \theta \approx 1## to the original Lagrangian ( i.e. the equation you begin with ##L = T - U##).
You can only use them safely once you have done all the differentiation. For example:MatinSAR said:Thanks a lot for your help ...
Are you writing the Lagrangian near equilibrium points using Taylor series?Orodruin said:I mean, ultimately it is what I already said, you need to include up to quadratic terms in the Lagrangian if you want to have the linearised equations of motion. This is relatively easy to see. Suppose you have a Lagrangian that you expand to linear order in ##\theta## and its derivative ##\dot\theta##, then
\mathcal L = \mathcal L_0 + \theta \mathcal L_1 + \dot\theta \mathcal L_1' + \mathcal O(\theta^2)
Yes.MatinSAR said:Are you writing the Lagrangian near equilibrium points using Taylor series?
Not exactly. It has the wrong dimensions to be a frequency.MatinSAR said:To find the frequencies of small oscillations, I use the formula ##f = \omega / 2\pi##. I think ##\omega## is the coefficient of ##\theta## in the above equation.
So, if I write the Lagrangian this way… Can I substitute those approximations into this Lagrangian? Then, I apply the Euler-Lagrange equations to find ##x(t)## and ##\theta (t) ##.Orodruin said:Yes.
Yes. For small oscillations, we have: $$ \ddot \theta + \omega ^2 \theta = 0$$Orodruin said:Are you familiar with the differential equation governing the harmonic oscillator?
The entire point of the post was to show that you need to include up to second order terms to het the correct linearised behaviour. If you include the quadratic terms, sure, as long as ##\theta## is small.MatinSAR said:So, if I write the Lagrangian this way… Can I substitute those approximations into this Lagrangian? Then, I apply the Euler-Lagrange equations to find ##x(t)## and ##\theta (t) ##.
MatinSAR said:Yes. For small oscillations, we have: $$ \ddot \theta + \omega ^2 \theta = 0$$
According to @PeroK, I should differentiate first. I am asking again because your way seems different to me…MatinSAR said:Or should I apply EL equations before applying approximations?
You should now simplify further by cancelling-out ##ml## in the second equation. (This then simplifies subsequent equations.)MatinSAR said:I rewrite equations in post #40:$$ (M+m)\ddot x +ml(\ddot \theta \cos \theta - \dot \theta^2 \sin \theta) = 0$$$$mgl \sin \theta+ml\ddot x \cos \theta + ml^2 \ddot \theta=0$$
I think you mentioned in an earlier post that the approximations were given as part of the question. The approximation that ## \dot \theta ^2 \approx 0## is not immediately obvious (to me, anyway) but makes sense.MatinSAR said:We have these approximations: $$\cos \theta \approx 1$$$$\sin \theta \approx \theta $$ $$ \theta ^2 = \dot \theta ^2 \approx 0$$
You will get simpler equations if you cancel ##ml##, as noted above.MatinSAR said:After substituting we get: $$(M+m)\ddot x +ml\ddot \theta = 0$$$$mgl\theta + ml\ddot x+ml^2\ddot \theta =0$$ After solving for ##\ddot x## in first equation and substituting in second, we get: $$ \ddot x =\dfrac {-ml\ddot \theta}{M+m}$$ $$ mgl\theta + ml\dfrac {-ml\ddot \theta}{M+m}+ml^2\ddot \theta =0 $$ Simplifying : $$ (ml^2 - \dfrac {m^2l^2}{M+m})\ddot \theta +mgl \theta = 0 $$
Now, I have equations of motion: $$\ddot \theta + \dfrac {mgl}{(ml^2 - \dfrac {m^2l^2}{M+m})}\theta = 0 $$ $$ \ddot x =\dfrac {-ml\ddot \theta}{M+m}$$
No (as already noted by @Orodruin).MatinSAR said:I think ##\omega## is the coefficient of ##\theta## in the above equation.
Do you think my final equations are correct? After simplifying them the way you suggest…Steve4Physics said:You will get simpler equations if you cancel ##ml##, as noted above.
Yes.Steve4Physics said:No (as already noted by @Orodruin).
Can I continue this way(post #53) instead of writing the Lagrangian the way you suggested?Orodruin said:I would simplify the coefficient further:
\frac{g}{l} \frac{M+m}{M}
SureMatinSAR said:Can I continue this way(post #53) instead of writing the Lagrangian the way you suggested?
So far, I have not expanded the Lagrangian around an equilibrium point, so it’s a bit difficult.
I will try it, but after solving other questions of my assignment…
I was getting discouraged from solving the question. Thank you! I am going to try finding the frequency of small oscillations again.Orodruin said:Sure
The term that gets dropped is ##\theta \dot \theta^2##. Which is effectively taken to be small compared to ##\ddot \theta##. If we expect SHM, then the order of ##\ddot \theta## is ##\omega^2 \theta##. Whereas, the order of ##\theta \dot \theta^2## is ##\omega^2 \theta^3##.Steve4Physics said:I think you mentioned in an earlier post that the approximations were given as part of the question. The approximation that ## \dot \theta ^2 \approx 0## is not immediately obvious (to me, anyway) but makes sense.
I did not. AI did. I just defined constants like ##\alpha## and ##\beta## to make calculations easier. So I didn't waste time in solving for ## x(t)## and ## \theta (t)##.Orodruin said:You don’t need to go through the hassle of solving the ODE.
Orodruin said:Just identify ##\omega## from the ODE.
Like what I've said in my last post?Can I find frequency of small oscillations by comparing ##\ddot \theta + \dfrac {g}{l} \dfrac {m+M}{M} \theta =0## with ## \ddot \theta + \omega ^2 \theta =0##?
