Find the x Coordinate of the Center of Mass of 3 Chocolate Blocks
To find the x-coordinate of the center of mass for three chocolate blocks with given masses and coordinates, the formula used is (mass1*x1 + mass2*x2 + mass3*x3) / (m1 + m2 + m3). Initial calculations yielded results of 0.051 and 0.05, which were deemed incorrect. After recalculating and ensuring no mistakes were made in the input, the correct x-coordinate was determined to be approximately 0.055543. The final answer was confirmed to be accurate after checking calculations on different devices. The discussion highlights the importance of careful calculation and verification in solving physics problems.
Heat
Three odd-shaped blocks of chocolate have the following masses and center-of-mass coordinates:
(1) 0.310 kg, ( 0.200 m, 0.310 m);
(2) 0.410 kg, ( 0.110 m, -0.380 m);
(3) 0.200 kg, ( -0.280 m, 0.610 m).
Find the x coordinate of the center of mass of the system of three chocolate blocks.
This is how I commenced,
I took (mass1*x1+mass2*x2+mass3*x3)/(m1+m2+m3) and got .051
this should be right but I got it wrong. I then redid the calculation and this time I got .05
not that much difference, I only got one try left, and don't think this is right because they are so close together.
I did the y the same way and got it right. :S
Please and thank you.
Well, then you have put in the wrong numbers somewhere (I assume that even though you have written m3*x2, that should read m3*x3)
It is impossible for us to know how you clicked about on your calculator.
You should, at least, calculate the following:
\frac{0.310*0.200+0.410*0.110-0.2*0.28}{0.92}=\frac{0.062+0.0451-0.056}{0.92}=\frac{0.0457}{0.92}
which ought to be about what you've found already..
for some reason, either my calculator is wack, for the numerator I keep on getting
.062+.0451-.056 = .0511
for the denominator I get .92
.0511/.92 = .055543478
:cry:
edit: I tried it on windows, and I get .0511 too. :O
for your x i got .055543. try that and see if it works. I did it how you had it up there and that is what I got. I did this on my homework yesterday and got it right so it should be right. :)
yep, it's right thanks. I it just as it showed in the calculator this time without any rounding. :)
thank you princessfrost and arildno for your help.
  • · Replies 25 ·
