Finding acceleration from Velocity vs Position graph
The discussion focuses on determining acceleration from a velocity vs. position graph, clarifying that the derivative cannot be taken directly as it would be with a velocity vs. time graph. The equation v = cx is used to derive acceleration, leading to a conclusion that eliminates several answer choices based on the characteristics of the graph. The chain rule is applied to express acceleration in terms of position, resulting in the equation a = m^2x + mb. This formulation rules out options B, C, and D due to their linear and non-zero characteristics. Ultimately, the correct answer is confirmed to be E.
iceninja3
The velocity versus position plot of a particle is shown on the right. Which of the following choices is the correct acceleration vs position plot of the particle (picture attached)?
dv/dt = a
dx/dt = v
The answer is E. I was initially very confused as to why the answer was not A but realized that the graph was velocity vs position (rather than velocity vs time) which means I can't simply take the derivative of the given graph.
One thing I tried was writing out the equation first(c being a constant):
v = cx
*differentiating both sides with respect to time*
a = c•(v) = (c^2)•x
So a constant times x which rules out choices B and D.
Having recognized that I am still not sure how to move forward to prove to myself the answer is E. Any hints?
Think about the velocity as a function of ##x## as a linear function:
$$v(x) = b + mx $$
You are going to use the chain rule to get ##\frac{dv}{ dt}##
$$v(x) = b + mx $$
Ohhh I see. So if I do the chain rule I would get:
a = mv and then substituting x back:
a = m(mx+b)
a = m^2x + mb
m^2x + mb rules out B and D because x is linear. And rules out C because the y-intercept is nonzero. And rules out A because the slope is nonzero.
Thank you so much!
Likes erobz and SammyS
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 30 ·
