Finding focal length from di v. M graph
blank44544
Using the di v. M graph, how would you find the focal length? The slope is 11.24. The y intercept is 8.753.
1/di + 1/do = 1/f
M = di/do
di = f (1+ di/do)
I tried di= f +fM, but that would mean slope and y int is the same when it’s not.
If you rearrange your equation to f = di/(1+M) that might be easier to solve since your graph is di vs. M.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
