Finding Specific Heat of a solid
The discussion centers on estimating the specific heat of copper using the known specific heat of aluminum and their atomic masses. A participant proposes a calculation based on the ratio of atomic masses, leading to an estimated specific heat of 382 J/kg-K for copper. The conversation emphasizes the importance of understanding the underlying principles, such as atomic oscillations in solids, which contribute to specific heat. A reference to a reliable source confirms that the accepted specific heat of copper is actually 0.386 J/gm K. The dialogue highlights the need for careful reasoning and adherence to homework guidelines when seeking help.
sarahjohn
For most solids at room temperature, the specific heat is determined by oscillations of the atom cores in the lattice (each oscillating lattice site contributes 3kT of energy, by equipartition), as well as a contribution from the mobile electrons (if it's a metal). At room temperature the latter contribution is typically much smaller than the former, so we will ignore it here. In other words, you can reasonably estimate the specific heat simply by counting the number of atoms!
Use this fact to estimate the specific heat of copper (atomic mass = 63.6), given that the specific heat of aluminum (atomic mass = 27.0) is 900 J/kg-K.
Q = mc(delta T)
I thought it might me a ratio of the atomic masses.
27 / 63.6 = x / 900
x = 382 J/kg-K
Steve4Physics said:
Hi @sarahjohn. In accordance with the rules here, you need to show that you have made some effort yourself before we can offer help. See Item 4 here: https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Having said that, I will add that you should carefully read your homework statement. Does it suggest any possible approach?
Thank you for letting me know! I have updated my question.
Likes Steve4Physics
sarahjohn said:
Homework Statement:: For most solids at room temperature, the specific heat is determined by oscillations of the atom cores in the lattice (each oscillating lattice site contributes 3kT of energy, by equipartition), as well as a contribution from the mobile electrons (if it's a metal). At room temperature the latter contribution is typically much smaller than the former, so we will ignore it here. In other words, you can reasonably estimate the specific heat simply by counting the number of atoms!
Relevant Equations:: Q = mc(delta T)
27 / 63.6 = x / 900
x = 382 J/kg-K
Maybe! But is that a guess or is there some reasoning behind it? What is the reasonng?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
