Finding the current and the voltage across each resistor
The discussion focuses on calculating the current and voltage across each resistor in a circuit with a total voltage of 24V and four resistors: R1 (270 ohms), R2 (330 ohms), and two R4 (1.2k ohms). Participants clarify that R1 and R2 are in series with the combined resistance of the two 1.2k ohm resistors, which are in parallel. The effective resistance of the parallel resistors is calculated to be 600 ohms, leading to a total resistance of 300 ohms when combined with R1 and R2. The provided current values for each resistor are confirmed, but the method to derive these values is discussed and clarified. Understanding the series and parallel relationships is crucial for solving the circuit correctly.
Lopez
Find the current and the voltage across each resistor.
volts is 24v
R1=270 ohms
R2=330 ohms
R2=1.2k ohms
R4=1.2k ohms
This is not a homework its more like a study guide.
He gave us the answer for just the currents which are
IR1=20
IR2=20
IR3=10
IR4=10
But not sure how he got that.
this is what i did but don't know how to go from there:
(270+330)|| (1.2k||1.2k)
600||600
R=300
Hi Lopez. Welcome to physics forums!
The 270 and 330 are in series with the 600, not parallel.
Chet
Having reduced the (1.2k||1.2k) to an effective 0.6k, what is the relationship of that in the circuit to R1 and R2?
ahh yes there was the problem,after 1.2 k and the other 1.2k were combined it becomes one resistor in series with the (r1 and R2). Thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
