Finding the force of the femur on the knee cap.
  • Thread starter Thread starter meaganl
    Force
The discussion focuses on calculating the force exerted by the femur on the kneecap, given a force of 420 N applied by the quadriceps muscle through a tendon. The model simplifies the leg's anatomy, treating the femur and tibia as beams connected by a pin, with the kneecap acting as a pulley. The user attempts to resolve the forces in both x and y components, resulting in a calculated femur force of approximately 191.4 N in the x-direction and -1.67 N in the y-direction. There is also a request for a larger diagram to better visualize the problem. The conversation highlights the complexities of biomechanics in force analysis.
meaganl
The diagram of the leg shows the femur (1) and tibia (2). The quadriceps muscle (3) applies a force to the lower leg via a tendon (4) that is embedded with the kneecap (5). If the force applied by the muscle to the tendon is FM = 420 N, what is the force of the femur on the kneecap? A simplified model of the leg is shown next to the diagram. The leg bones are represented by two beams attached by a pin. The tendon is modeled by a rope and the kneecap acts like a pulley. The tendon above the kneecap makes an angle θ1 = 23° with respect to the vertical, and the portion of the tendon below the kneecap makes an angle of θ2 = 24° with respect to the vertical. Enter the x component, followed by the y component.
https://www.physicsforums.com/attachment.php?attachmentid=51494&thumb=1&d=1349314642
fnet=ma
I tried:
Fnetx=max
T1x + T2x + Ffemurx = 0
-240sin23 + -240sin24 + Ffemurx= 0
-93.78 -97.62 + Ffemurx=0
Ffemurx= 191.4N
Fnety=may
T1y + T2y + Ffemury=0
240cos23 -240cos24 + Ffemury=0
220.92-219.25 + Ffemury=0
Ffemury=-1.67N
I see only very small picture. Can not you show a bigger one? ehild
