Finding the Magnitude of a Diplacement Vector
  • Thread starter Thread starter Love_to_Learn
    Magnitude Vector
Cavers traveled 2.6 km west, 3.9 km south, and 25 meters upward, leading to a displacement vector of r = -2600i - 3900j + 25k. The magnitude of this displacement vector was calculated as approximately 4.69 km. There was confusion regarding the difference between displacement and magnitude, with clarification that a displacement vector includes both magnitude and direction. The discussion emphasized the importance of understanding these terms correctly in vector analysis. Overall, the final magnitude of the displacement vector was confirmed as 4.69 km.
Love_to_Learn
1. Cavers spelunked 2.6 km westward, 3.9 southward, and 25 meters upward. What is their displacement vector?
- The formula for the magnitude of a vector which is
sqrt of [(3.6)^2+(2.9)^2+(0.025)^2] ≈4.623 km
Let the point P1 lie at (-2600, -3900, 25).
Then OP1 will be a line segement whos magnitude is denoted as follows
sqr[ (-2600)^2 + (-3900)^2 + (25)^2 ] = 4687.28m = 4.69km
Looks about right, assuming it's 3.9km southward.
EDIT: I failed to read the question, The displacement vector would simply be r = -2600i -3900j + 25k, where i, j, k are the unit vectors of x, y, and z.
2nd EDIT: I reread the title and if you're looking for the magnitude of that displacement vector it is indeed 4.69km, sorry for the confusion.
Alright, then I am not understanding how to find a displacement vector. I thought that the displacement of a vector was the same as its magnitude. How is finding the displacement of a vector somehow different than finding the magnitude of a vector?
The displacement vector conveys both magnitude and direction. You have the distance, does the problem want direction as well?
I think you are mixing up terms, its not a vector with a displacement, its a displacement vector, this is a vector that defines displacement of an object based on another parameter(usually time).
You were exactly correct. That is what I was doing. Thanks for the replies everyone.
