MHB Finding the Rotation Vector $\omega$ of a Sphere
The rotation vector $\omega$ of a sphere is equal to the angular velocity vector. In this case, the sphere rotates around the z-axis with an angular velocity of 4, indicating a counterclockwise direction when viewed from the positive z-axis. The relationship is defined mathematically by the equation $\vec{\omega}=\frac{\vec{r}\times\vec{v}}{\vec{r}\cdot\vec{r}}$, where $\vec{v}$ represents the tangential velocity at a point on the sphere. Thus, the rotation vector directly corresponds to the angular velocity in this scenario. Understanding this relationship is crucial for analyzing rotational motion.
evinda
MHB
Hello! (Wave)
A sphere with radius $10 cm$ and center $(0,0,0)$ turns around the $z$-axis with angular velocity $4$ and with such a direction that the rotation has counterclockwise direction, being seen my the positive semi-axis $z$.
I want to find the rotation-vector $\omega$.
Is this equal to the vector of the angular velocity? If so, why? (Thinking)
Mathematics news on Phys.org
evinda said:
Hello! (Wave)
It is - by definition. The rotation vector $\vec{\omega}$ IS the angular velocity! It's defined by
$$\vec{\omega}=\frac{\vec{r}\times\vec{v}}{\vec{r}\cdot\vec{r}},$$
where $\vec{v}$ is the regular velocity vector in the tangential direction of a point on the circle or sphere.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
