Finding the x component of position vector
The discussion focuses on calculating the x component of a position vector for a ball affected by both gravity and an electric field. The initial calculations yielded a time of 3.377 seconds and an x displacement of 18.84 meters, but the expected answer is 31.13 meters. Participants point out that the force from the electric field and its resulting acceleration must be included in the calculations. It's emphasized that the assumption of no acceleration in the x-direction is incorrect, and the kinematic equations should be adjusted accordingly. Additionally, the importance of including units in calculations is highlighted.
hraghav
A ball of mass 𝑚=4.07kg is thrown over level ground in a region where the electric field is 𝐸⃗=5.5N/C𝑖̂. The ball has a charge 𝑞=1.59C. The ball was thrown from the origin with an initial velocity of 𝑣⃗𝑖=5.58m/s𝑖̂+16.55m/s𝑘̂. Gravity provides an acceleration of 𝑔⃗=−9.8m/s^2𝑘̂. What is the x-component of the position vector where the ball lands?
t = 3.377s
x = 18.84m which is wrong
I first calculated the time using y = (viy)(t) + 0.5gt^2 where y is the vertical displacement which is 0 for the ball landing back on the ground, viy is the initial vertical velocity ie 16.55m/s and g = -9.8m/s}^2. I get 2 values for t, t=0 and t= 3.377s. Then using the equation x = (vix)(t) = (5.58m/s)(3.377s) I get x as 18.84m. The correct answer is 31.13m and I am not sure where I am going wrong.
Could someone please help me with this and let me know where am I making an error?
Thank you
You are ignoring the force exerted by the electric field on the charged ball. What is that force? What acceleration does it provide? Rewrite the kinematic equations to reflect this correction.
F = qE = 8.745 and acceleration = F/m = 2.148 but how do I use these values in my question?
You have assumed that the ball is not accelerating in the x-direction in your solution. This tells you that it does have a constant acceleration that you must incorporate. You have already handled one case of constant acceleration in this problem so doing it again should be relatively straightforward.
Note: Never ever write numbers without appropriate units.
Likes MatinSAR and PeroK
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
