- #106
DaveC426913
- 6,344
An eloquent analysis and explanation!Rene Dekker said:In all cases, the buoyancy force is still there...
(Welcome to PF.)
I have a bucket full of water. Is there a buoyancy force on the bottom of the bucket? How about the upper half thickness of the bottom? Your argument holds no water.Rene Dekker said:There is a buoyancy force on the ball, that is counteracted by the force in the string tying it down to the floor.
I disagree with this statement. With a flat bottom to the boat and a water-tight seal, the buoyancy force is gone and replaced by a force from the bottom. Meanwhile air pressure forces are normally transferred as well to the buoyancy force, (i.e. the same air pressure that acts above also acts from underneath), but those also disappear with the water-tight seal, and then the air pressure only acts from above to pin the boat to the bottom, along with water pressure from above that also adds to the air pressure.Rene Dekker said:In all cases, the buoyancy force is still there. It does not suddenly disappear when you replace the rope with a weld, or with a vacuum.
No, Rene! You are making the mistake that Haruspex pointed out in a recent reply. What do you know about hydrostatics? Look at the following drawing.Rene Dekker said:I wasn't, I was speaking of objects that are lighter than water, that are held to the floor through a water-tight seal. Although it does not matter for the principle. Your rubber ball example shows exactly what I was pointing out. There is a buoyancy force on the ball, that is counteracted by the force in the string tying it down to the floor. The same is true for an object that is held to the floor with a water tight seal. There is the same buoyancy force on the object, that is counteracted by a force from the floor. The same is true for an object that is welded to the floor. There is the same buoyancy force on the object, that is counteracted by the force through the weld.
In all cases, the buoyancy force is still there, it does not matter whether there is water under the object. It does not suddenly disappear when you replace the rope with a weld, or with a vacuum.
Agree. Further, the force between a flat boat bottom and a flat surface against which it tightly mates is indeterminate. It can take on a range of values depending on the other forces on the boat. One can pull strongly upward on the boat while the pressure from the water above resists motion. Or one can push strongly downward on the boat while the normal force from the ground below resists motion.Charles Link said:I disagree with this statement. With a flat bottom to the boat and a water-tight seal, the buoyancy force is gone and replaced by a force from the bottom.
I tried this with several flat bottom containers with straight sides including a cube but I could not sense the buoyancy force diminish as the object was pushed against the bottom and the water squeezed out. Next, I put a weak seal (toothpaste) around the base of the cube resting on the bottom to keep it dry underneath before putting water in the tank. It held for about ten seconds till the water worked its way underneath. This may be a very small scale experimental confirmation of the original thesis of floating on a very thin layer of water.italicus said:Now, consider a cubic box made of steel , 5 mm thickness of each wall and 1 square meter of each face. When put free into water, it floats, because it is lighter than an equal volume of water; its mean density, mass/volume, is less than that of water . Push it until it reaches the bottom of the pool, and weld it all around the base perimeter ( suppose the pool too is made of steel) . After having welded it this way , no pressure acts beneath , because no water is there. The pressure acts on the four vertical walls and the horizontal upper surface.
No buoyant force acts on the cube.
Of course, the water level of the pool has increased , but this means only an increase of max pressure at the bottom, as well as at any surface of objects in fixed position in the pool.
Yeah, I think we are done. I’ve nothing more to add, really.hutchphd said:Nice use of materials (the toothpaste is perfect...first it seals, then it doesn't).
Are we done here?
Please?
