FLUIDS-how far from dam base does stram hit ground
  • Thread starter Thread starter ricky882
    Base Ground
To determine how far from the base of a dam a stream hits the ground when a hole is located halfway down, Bernoulli's equation is essential for calculating the velocity of the fluid. After finding the velocity, the next step is to calculate the horizontal distance the fluid travels, denoted as distance x. The discussion emphasizes the importance of understanding the principles of fluid dynamics and projectile motion. Participants confirm the need to apply these concepts to solve the problem effectively. The conversation centers around the application of physics equations to achieve the solution.
ricky882
a dam of height H has a hole half way down to the base. how far outward from the base does the stream hit the ground?
i think you have to use bernoulli's equation right?
first find velocity then distance x right?
Assume that the fluid is just a ball. If someone throws a ball from an elevated location, what information must be known in order to determine how far he throws it?
Welcome to PF!
Hi ricky882! Welcome to PF! :wink:
Right! :smile:
What do you get?​
  • · Replies 17 ·
