Flux density and Divergence of Electric field
Flux density is defined as the amount of electric flux passing through a unit area, while divergence measures the rate at which electric field lines spread out from a point in space. The discussion clarifies that flux density can be understood as electric field per unit area vector. Divergence is specifically defined as flux per unit volume, indicating a distinction between the two concepts. Overall, the participants agree that flux density and the divergence of the electric field are different quantities.
Shreya
Is flux density same as divergence of electric field
Div E = (lim as V tends to zero) of (1/V) E*dS
V is volume
I think Flux density is flux/Volume.
Or is it flux/ Area
Please be kind to help
Divergence is defined as flux per unit volume.
Thanks a lot, Gordianus!
I think flux density is electric field / unit area vector...
So flux density and divergence of E are different,right?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
