- #71
Zlatko1969
- 14
First of all
thank you guys for replys
tech99 yes i read Tom points and i think that have a right.
1) The circuit shows a GND symbol and a wire labeled GND (+) RAIL. What is happening?
- yes GND or grounding point is (+) ,simply cannot be on (-) because this colpitts oscillator require grounnding
on (+), for example if i connect 330pF to MINUS, or 5nF then oscillator stop to work
2) The Base wiring in this circuit is a lot different than in post #1. For instance C6 here connects to GND (+)
RAIL but the original circuit shows that capacitor connected to the Base of Q1.
- yes it is different and that is why i ask in first place and i want to know if circuit #1 is a maybe better
solution.Also 330pF is connected to base of transistor not on GND like in my case.
3) L1 C7 resonate somewhere around 30-50MHz. Is that the frequency you need?
- this resonant circuit is a mistery to me and i cannot explain to myself what is a purpose of
33pF + 280nH which gives cca 52Mhz resonant frequency
No , of course that i don't need it . I just need to build ordinary FM mixer/oscillator
which should mix local oscillator signal with incoming FM sinal, heterodyne effect
as usual Fif = fosc - fin should give cca 10.7mhz
That miswire of C6 is probably a cause of the "unstable" you describe.
L1 C3 frequency could be the problem of "can tune few strongest station"
