Force between 2 point charges in VECTOR format (x i + y j + z k)
The discussion revolves around calculating the force between two point charges using vector format. The original poster attempted to find the force in the x, y, and z directions but received incorrect magnitude results from WebAssign, despite having the correct direction. Participants clarified that the magnitude of the force should be calculated using the total distance between the charges, not the individual components. They emphasized the need to compute a unit vector from the distance vector and then multiply it by the force magnitude derived from Coulomb's law. Ultimately, the poster acknowledged the misunderstanding and expressed gratitude for the assistance.
nataelp
Point charges
q1 = 4.0 µC and q2 = 4.0 µCare located at r1 = (4.0î − 5.0ĵ + 2.0k) mand r2 = (9.0î + 5.0ĵ − 6.0k)m What is the force (in N) of q2 on q1? (Express your answer in vector form.)
F = k*q1q1/r^2
I tried using the distance between r2 and r1 and plugging them into the equation for i, j, k. >>
So for the force in the x direction it was k*(4E-6*4E-6)/(4-9)^2. The answer I got was wrong according to webassign. Can someone please tell me what I am missing?
And to be clear it was not the direction of the vector that was wrong, I can see that the magnitude is completely off, but the direction was correct.
What magnitude did you get?
I got (-0.0058, -0.00144, 0.00225)
What's the vector from ##q_2## to ##q_1##?
It should be 13.72 using the Pythagorean theorem.
That is the magnitude of that vector
If you mean in the vector form, it would be <-5^2, -10^2, 8^2>. And those are the values for r I used to find the force on each axis. The answer WebAssign gave me was this:
My problem is I don't know how to get to this answer.
I get that answer. How did you try to solve the problem?
So I did this:
For the force along each axis, I used F= k*q1*q2/r^2. I had the charges, and k is a known value, so I just needed the distance r.
For r along the x-axis, for example, I used 4-9 as r because it should be the distance in the x-direction. So I solved it with that value and got my answer for force in the x direction. I repeated it for x, y, and z.
I'm not sure where I am going wrong. And I did change it from microcoloumbs to coloumbs.
nataelp said:
So I did this:
Ah, this is not right. Once you have the magnitude of the force, you just need to calculate a unit vector in the right direction.
So I need to find the magnitude of the vector from q2 to q1 (in m), use that as r, and then to find the force along the i j k directions, I need to calculate a unit vector along those directions? Then multiply by that unit vector, which is each component divided by the magnitude?
Yes, Coulomb's law is:$$\vec F = k\frac{q_1q_2}{r^2} \hat r$$where ##\vec F## is the force of ##q_2## on ##q_1## and ##\hat r## is a unit vector from ##q_2## to ##q_1##. And ##r## is the distance between the two charges.
How can I calculate a unit vector for force without its components though? Or am I supposed to calculate a unit vector for the distance and then multiply by that? I'm honestly not sure what you mean.
Should the unit vector be <-5, -10, 8>/13.75 (magnitude of distance vector)? Then I multiply "F = k*q1*q2/13.75^2" by that unit vector, and I have my answer?
No, you don't divide the q1*q2 in each direction by the square of the distance in that direction. You have to divide each by the square of the total distance between the charges.
I have figured out the problem now. Thank you all for your help!
I suggest you revise your knowledge of vectors.
14K
10K
