Forced SHM with damping problem
  • Thread starter Thread starter asaspades
    Damping Shm
The discussion revolves around the forced simple harmonic motion (SHM) of a mass attached to a spring, subject to damping and periodic force. The equation of motion incorporates terms for damping, spring constant, and external force, with solutions explored for both undamped and damped cases. Key findings include the derivation of complex constants for the system's response, particularly under varying conditions of damping and applied force. The relationship between the constants from the solutions is established, leading to a tangent relationship involving phase angles. The thread highlights the complexity of the problem, with participants seeking clarity on the derivations and initial conditions.
asaspades
A mass, m, attached to a spring hangs vertically downwards under gravity. It is subject to a viscous damping force proportional to its velocity. The spring constant is k > 0.
A periodic force is applied to the spring and the equation of motion for the mass is
\ddot x+ \frac{b}{m}\dot x+\omega_0^2x=fe^{i\omega t} with b>0, m where f = |f|e^{i\phi_f} with |f| and f real constants. The applied force per unit mass should be taken to be the real part of the term on the right hand side.
(i) Explain the origin of the terms in the equation of motion of the mass.
(ii) For the case f = 0, assume a solution of the form x(t)=Ce^{i\alpha t} \text{ with } C=|C|e^{i\phi_C} where |C| and \phi_C are real constants. Find the real and imaginary parts of \alpha for the case b/2m<\omega_0.
(iii) Now consider the case with f \neq 0. Assume a solution of the form x(t) = Ae^{i\omega t} and find an expression for the complex constant A = |A|e^{i\phi_A} .
(iv) Show that the sum of the solutions from parts (ii) and (iii) above is also a solution to the equation of motion. The initial conditions are x(0) = 0 and \dot x(0) = 0. Use these to find two relations between the constants |C|, C, |A| and A. Hence show that \tan{\phi_c} = \frac{\omega}{\omega '} \tan{\phi_A} - \frac{b}{2m\omega '}, where \omega ' is the real part of \alpha from part (ii).
Part (i) easy
Part (ii) get \alpha = \frac{ib}{2m}\pm \sqrt{\omega_0^2 - \frac{b^2}{4m^2}}
Part (iii) get A=\frac{f}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}}\left(\frac{\omega_0^2 - \omega^2}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}} - i\frac{b\omega/m}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}}\right) giving \tan\phi_A = \frac{-b\omega/m}{\omega_0^2 - \omega^2}
Part (iv) Obviously a combination of the two is a solution. Using the given initial conditions x(0) = A+C = 0 \Rightarrow A=-C and \dot x(0) = i\alpha Ce^{i\alpha t} + i\omega Ae^{i\omega t} \Rightarrow \alpha e^{i\alpha t} - \omega e^{i\omega t} = 0 (not going anywhere with this part)
Since A = -C i.e. |A|e^{i\phi_A} = -|C|e^{i\phi_C} we also have |A||e^{i\phi_A}| = |C||e^{i\phi_C}| \Rightarrow |A|=|C| and \phi_A = \phi_C + \pi.
Taking \tan of both sides, \tan\phi_A = \tan\phi_B which is wrong...
This is from a past exam paper, only 1 person was able to do it in the exam. Anyone have a flash of brilliance?
Anyone?
