What is the Magnitude of the Third Force in a Three-Force System?
  • Thread starter Thread starter purplecows
    Forces
In a three-force system where an object moves at constant velocity, the net force must equal zero. Given a 150 N force along the x-axis and a 100 N force at a 120° angle, the third force's magnitude can be determined by resolving the forces into their x and y components. The sum of the forces in both directions must balance out to maintain equilibrium. This leads to two equations based on the x and y components, allowing for the calculation of the unknown third force. Understanding these principles is crucial for solving the problem effectively.
purplecows
An object that is moving at a constant speed velocity is acted upon by three forces. One force is 150 N along the x-axis, the second is 100 N along a direction making a counterclockwise angle of 120° with the x-axis. What is the magnitude of the third force?
Not sure, these are the only ones I THINK are remotely relevant (but I have no idea which is why I'm posting here)
F_x = Fcosθ
F_y = Fsinθ
I thought it would just be either 100 N (the same as the northwest force 120° from x-axis) or it would be something involving the Pythagorean Theorem (100^2 + f^2 = 150^2 or 100^2 + 150^2 = 150^2)
Anyone? This is urgent. My whole class is confused.
Since it's moving at a constant velocity, what is the sum of the forces on the object?
zero
And the x and y directions are independent. So you have two equations, two variables, yeah?
