Forces Experienced On Moon and Earth - What is the mass?
The discussion revolves around calculating the mass of an object based on the forces of gravity experienced on the Moon and Earth. The initial calculations led to confusion regarding the relationship between the forces, with attempts to establish an equation that accurately reflects the difference in gravitational force. The correct equation derived is m(9.8) = m(1.62) + 25, which simplifies to find the mass as approximately 3.056 kg. Participants clarified the importance of expressing the gravitational forces correctly and confirmed the final mass calculation. The conversation emphasizes understanding the relationship between gravitational forces on different celestial bodies.
lola1227
an object on earth experiences a force of gravity which is 25N larger than the moon. If g(earth) = 9.8m/s^2 and g(moon) = 1.62m/s^2 .what is the mass of the object?
F=mg?
So, I decided to do
Fg=ma
I tried 25(9.8)=1.62m
m= mass
However, when i did it i got a mass of 151 but when i put it into its separate equations, the fg is not 25x larger
so fg=ma
fg=151(9.8)
= 1479.8and then fg=ma
fg=151(1.62)=
244.62
but 1479.8/244.62 is not 25 it ends up being 6.05
so i do not know where to go from here.
Let Fe represent the force of gravity experienced by the object when the object is on the earth.
Let Fm be the force of gravity when the object is on the moon.
Can you write an equation that relates the symbols Fe, Fm, and 25N?
Likes Delta2
would it be fe(25)=fm?
or with numbers (9.8)(25)=(1.62)?
I don't see anywhere in the problem that friction is involved. Why is friction mentioned in your thread title?
Edit: Thread title edited to better reflect the actual problem.
This is not correct. You need to express the fact that fe is 25 N larger than fm.
Likes Delta2
my bad. I changed the title
so fe+25=fm
lola1227 said:
so fe+25=fm
That's better, but still not quite correct. If fe happened to be 50 N, what would your equation give for fm? Would the result make sense?
Likes Delta2
i see. would the equation be
m(9.8)=m(1.62)+25?
Likes Delta2
m(9.8)=m(1.62)+25?
Yes. Make sure that you feel confident with this equation.
Likes lola1227
9.8x=1.62x+25
9.8x-1.62x=25
8.18x=25
x=3.056??
so would the mass be 3.056kg?
Likes Delta2
lola1227 said:
9.8x=1.62x+25
9.8x-1.62x=25
8.18x=25
x=3.056??
Yes. (I don't know if you are required to express the answer with an appropriate number of significant figures.)
Likes lola1227
Thank you very much for your help!
You are welcome.
12K
