Frames of Reference: Using tie-downs to hold a load on a flatbed truck
The discussion focuses on calculating forces acting on a load secured with tie-downs on a flatbed truck. A net force of 6500 was determined, indicating that kinetic friction is at play since it exceeds static friction. Participants clarify the equations for net forces in both x and y directions, emphasizing the importance of including the normal force and the effect of tie-down straps. The correct expression for the force of friction is confirmed as Ff = coefficient of friction * (Fstraps + Fgravity). Understanding these forces is crucial to prevent the load from slipping during transport.
daisy7777
A flatbed truck has a 2000.0 kg component of a pre-fab house placed on its flatbed. If the coefficient of static and kinetic friction, respectively, between the pallet and the flatbed is 0.150 and 0.100, and the truck starts at rest and accelerates to a speed of 65.0 km/h over a distance of 50.0 m. The component is strapped down by tie straps wrapped over the top of the house component so as to push down on it; with what force must the tie straps push down on the house component in order to prevent the truck from slipping while accelerating?
Fnet = ma, Ff = coeff of friction * normal force, Fnet = 0 when not accelerating
I calculated the net force. I got 6500. I determined this is bigger than the force of static friction so the force of friction acting on the object must be kinetic. From there I got kinda lost. I know for the component to not slip Fnetx = 0 and Fnety = 0. But I'm not sure what to do from there? Is it (in the y-dir) 0 =Fn - Fstraps - Fg? Or (in the x-dir) 0=Ff+Ffict-Fstraps?
What is the normal force? Don't forget the straps.
Wait so the force of friction is gonna be Ff = coeff of friction * (Fstraps + Fgravity)?
Yes. If the magnitude of the normal force were only Fg then you would have Fg acting up on the slab but Fg+straps acting down on it, so it would be accelerating downwards!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
