Freeboard of a Soup Can in a Pool
  • Thread starter Thread starter waterwalker10
The discussion revolves around whether a soup can filled with rusty ball bearings will float in a pool and how to calculate its freeboard. Participants confirm that the can's weight is 0.5 pounds, which converts to approximately 2.224 Newtons. Calculations show that the can's volume is 282.74 cm³, and the specific gravity is calculated, indicating it is less dense than water. The key focus is on determining the volume of water displaced to find how much of the can will be submerged, leading to a final freeboard calculation of approximately 1.97 cm. The conversation highlights the importance of using the correct formulas and conversions in fluid mechanics.
waterwalker10
Willie took a soup can from the kitchen trash, added a handful of rusty ball bearings from the bottom of his Dad's junk drawer, and is now about to put it into the deep end of the family pool that Dad has just finished cleaning. Dad is not amused. "Don't worry," Willie says, "It'll float." "It had better," his Dad says, "or you'll be going in after it."
The can, plus bearings, weights exactly 0.5 pounds (force). Measurements are shown on the right. Will the can float? If so, how much freeboard will it have? (Freeboard, a nautical term, is distance between the waterline of a ship, and the ship's deck. In this case, it's the distance from the water level to the top of the can.) Show your calculations. (Hint: Convert pounds (force) to Newton’s and work in the MKS system.)
Archimedes Principle?
lbs to Newtons
Vol=Pi*h*r^2
Freeboard = distance from the water level to the top of the can
Ok so here is where I get confused. I believe the can will float because the can is less than 1 kg/l which is the density of water. So far here is what I have...any suggestions on where to start?
Weight = .5
Converted to Newtons
.5lbs*4.4482216 = 2.224 N
Calculated Volume of Soup Can
3.14159*10cm*32
V = 282.74
Here is the image. BTW this is an old homework assignment that I never could figure out...any help is much appreciated. Thanks.
OP did you ever figure this out... I have this exact same problem and can't figure it out!
As a matter of fact I got the exact same answers as you did above with the add info below:
density of can (pc)=0.805cm3
after that I get just as stuck you were.
It's an old post; the OP may no longer be around or be interested in this particular question. Why don't you show your own work on it?
Hint: How about if you were to consider how much of the can, with the given base area, would have to be submerged in order to displace the can's weight in water?
ok, well after looking at this for a VERY long time and using a friends help this is what I have come up with...
Vc=282.74cm3
Mc=0.227kg
Finding the specific gravity of the can (pc):
pc=m/V
pc=0.227/0.2827
pc=0.805m3
Taking this and the mass of the can I *think* that I can find the volume of displaced water
Displacement(diss)=mass/pc
(diss)=227/0.805
(diss)=281.99
I then took the volume of the can (282.74cm3) and subtracted the displacement (281.99cm3) which game me 0.75cm3
Knowing this I reversed the area equation used to find the volume of the can Vc=\pir2h \rightarrow h = \pir2/Vc to find the height of the can out of water
which I found to be .0283cm \rightarrow 28.3\mum
If this is wrong SOMEONE please point this out to me! I have no clue if I did this right or not.
Vc=282.74cm3
Mc=0.227kg
pc=m/V
pc=0.227/0.2827
pc=0.805m3
You've lost some accuracy here, possibly due to rounding and/or using a not too accurate value for g. The number should be closer to .80213 g/cm3 (or perhaps kg/L, since you seem to have converted the volume units to liters for your calculation).
(diss)=227/0.805
(diss)=281.99
That would be the volume of displaced water if the WHOLE CAN was submerged. Effectively you've done the calculation:
p_c = m_c/v_c
diss = m_c/p_c = v_c
Which doesn't produce any new information...
The difference in value between this result and the volume that you calculated previously for the volume of the can is due to the rounding error mentioned above.
I'm not sure why you would want to calculate the specific gravity (actually the density) of the can, except as a check to see if it is less than the density of water and thus can float. Once that is ascertained you don't really need the can density.
Instead, use the density of the water (the thing that's being displaced) to determine what volume of water needs to be displaced in order to equal the weight of the can. Then look at how much of the can needs to be submerged in order to displace that volume of water.
I see where I might have gone wrong, but...
so should I use this formula to find the water displaced?
diss = m_c/p_w = v_w
If so that doesn't seem right to me... would I take this new displacement and try to convert it back to Newtons so that I can find the weight difference? After that... what?
and how would I find how much needs to be submerged? The previous attempt was the best that I had...I'm so lost...
Yes. This is the amount of water that the can must displace if it is to float; the can floats when it displaces a volume of water whose weight (or mass) is equal to the weight (or mass) of the can.
This "new displacement", as you put it, is the amount of the can that needs to be submerged; the portion of the can that is underwater and displacing water.
You now have the volume of the portion of the can that needs to be submerged. You should be able to work out the length of the can cylinder that corresponds to that volume. What's the formula for the volume of a cylinder?
OK So I took your equation and I think that I did the math correct, but I think that some of my conversions are incorrect in places.
Anyway: here is what I got
diss = 227/1 = 227cm^3
Taking that and subtracting the original volume of the can:
New Vol = 282.74-227
New Vol = 55.74 cm^3
Now taking this and plugging it back into the volume eqation:
V = \pi r^2h
H = \pi r^2/V
H = \pi 3^2/ 55.74
H = 1.97cm
So I *think* that my answer should be 1.97cm of freeboard?
Like I said I know that somewhere in that my conversions went a little wacky but I think that my answer is right this time.
Looks good to me! :smile:
Thank you so much for all your help!
