Friction and tension force- mass
The discussion revolves around calculating the mass of a cow, Brisket, being pulled up a ramp with friction. The ramp is inclined at 26.6° with a coefficient of kinetic friction of 0.674, and a tension force of 5060.8N is applied. The user initially attempted to use a specific equation but arrived at an incorrect mass of 916.31 kg. Participants suggest analyzing the forces acting on Brisket and applying Newton's second law to find the net force. The key is to express the friction in terms of the normal force and to sum the forces parallel to the incline to solve for the mass accurately.
Paulbird20
Friction and tension force-- mass
In the real world, ramps aren't frictionless, so I had to drag Brisket up a ramp, slanted at 26.6° from the ground, that had a coefficient of kinetic friction = 0.674. I applied a tension force FR=5060.8N to my pet cow using the rope. Brisket moved up the ramp with an acceleration of magnitude 1.54m/s2. With this information, including friction on the ramp, what is Brisket's mass (in kg)?
T= Uk*m*g/cos(angle)+Uksin(angle)
Fnet= ma
I attempted to use the first equation
5060.8 = .674 * m * 9.8 / (cos(26.6)+ .674 sin(26.6)
using this equation i got 916.31 kg which is incorrect
any tips would be much appreciated thanks
Where does this formula come from?
Instead, just analyze the forces acting on the cow and apply Newton's 2nd law:
Fnet= ma
ok so the forces i have acting on the cow are:
mgsin(angle)
mgcos(angle)
mg
Friction(going up the incline)
N(force)
im not sure how to arrive at Fnet because i need the mass to be able to get the components of it
mgsin(angle)
mgcos(angle)
mg
The weight (mg) can be broken into components.
Express the friction in terms of the normal force and μ. Which way does it act?
N(force)
Don't forget the tension force.
Find Fnet by adding up all the force components parallel to the incline. (There are three such components.) Set up an equation using Newton's 2nd law and solve for the mass.
  • · Replies 18 ·
  • · Replies 16 ·
