- #36
Mapes
- 19
physical1 said:Water is not a gas molecule, it is liquid.
Someone who would assert this is unlikely to be convinced no matter how many members and moderators try to explain the physics of the thought experiment. physical1, you're arguing from incredulity ("If this is the case then it means that water is in fact "decompressible" and can be ripped and pulled apart."), which is a pointless position to take in physics. Plenty of things occur in nature that are quite surprising when one first learns about them. But I'm not sure you're here to learn, or you would have examined your assumption about "decompressibility" and found it to be incorrect. (When one increases the volume of a container entirely filled with water, a vapor phase forms in the additional volume. At low pressure, it's the gas phase, not the liquid phase, of water that's most stable.) Instead, you seem to want only support for your misguided assumptions and hypotheses, and you're not going to get that support from the knowledgeable members of this forum.
