Gauss' law and flux concept issues
Flux is defined as proportional to the number of electric field lines passing through a given area. For a 2D circle enclosing a charge, the flux is calculated as 2q/Epsilon, which is correct. However, a 3D sphere with the same diameter also encloses the same charge, resulting in the same flux of 2q/Epsilon. The confusion arises because a sphere, being a closed surface, allows Gauss's law to apply, while a circle does not since it is not closed. Understanding that only closed surfaces can be used with Gauss's law clarifies the concept of flux in this context.
engineeringstudnt
Gauss's law and flux concept issues
flux=Qenclosing/Epsilon
Hi guys i have some concept issues about flux. My book says flux is proportional to the number of lines passing through that area. so my question is: first i am thinking that a 2D circle which has a 2r diameter and it is enclosing a 2q charge so its flux should be 2q/Epsilon.then i am thinking a 3D sphere which have a 2r diamater again. so its flux should be 2q/Epsilon too ,right ?
but how ? isn't the sphere has more electric field lines passing through its area ?
The Gaussian surface must be a closed surface. A circle in three-dimensional space isn't a closed surface, so Gauss's law won't hold.
Likes engineeringstudnt
thank you very much i am thinking about this almost 45 minutes :D
