PeterDonis
Mentor
- 49,163
- 25,226
JDoolin said:They are both legitimate ways of explaining what is going on. The light coming from the Rindler Horizon can't ascend from the horizon, and the light and objects falling toward the rindler horizon approach it asymptotically, but never reach it. Objects beyond the rindler horizon, mathematically also move toward the rindler horizon, but their clocks are mathematically going backwards.
In the view of the rocket, the event at (x=0,t=0) is an event that cannot be crossed because nothing can happen there.
If you use the term "horizon" to refer only to the single *event* at x = 0, t = 0, then I can see why you're describing things this way. Obviously a free-falling observer who drops off the rocket at event x = s_0, t = 0 will never pass through the event x = 0, t = 0. However, that observer *will* cross the line x = t (at x = s_0, t = s_0), so if the term "horizon" refers to that entire line (which is the standard usage, and also makes more sense--see below), it is simply false to say that "objects falling toward the rindler horizon approach it asymptotically, but never reach it". The objects' worldlines *do* reach the horizon, and pass beyond it. That's the fact. It is also a fact that observers in the rocket will never *see* that portion of a free-falling object's worldline, but that doesn't mean that portion of the worldline doesn't exist.
Why does it make more sense to use the term "horizon" to refer to the *line* x = t, instead of just the single *event* x = 0, t = 0? (Actually, if we include the other two space dimensions, the horizon is a null *surface* which includes the line x = t.) Because the hyperbolas along which the Rindler observers move, x^{2} - t^{2} = s_{0}^{2}, asymptote to the line, *not* the single point. Put another way, it's not just the single event x = 0, t = 0 that can't send light signals to any of the Rindler observers; it's *any* event on the line x = t (or in the region "above" it--i.e., with t > x--so the line x = t is the *boundary* of the region, which is what "horizon" means in standard usage). The only reason to single out the particular event x = 0, t = 0 is that it is the "pivot point", so to speak, of all the lines of simultaneity for the Rindler observers as they move along their hyperbolas. But since, as you note, nothing actually *happens* at that event, singling it out tempts you to ignore real stuff that *does* happen, like free-falling observers crossing the line x = t.
