B General Relativity & Grav. Time Dilation Qn
IXWELL
hello I'm korean high school student and sorry for my poor English.
I saw ## t_0=t_f\sqrt{1 -\frac{ 2GM}{rc^2}} ## in wikipedia.
does ## \sqrt{1 -\frac{ 2GM}{rc^2}} ## of this equation have name like lorentz factor ## \frac{1}{\sqrt{1 -\frac{v^2}{c^2}}} ##of ## t=\frac{t_0}{\sqrt{1 -\frac{v^2}{c^2}}} ## ?
or is it just called time dilation equation?
I just want to know if there is a word specifically referring to factor ## \sqrt{1 -\frac{ 2GM}{rc^2}} ##.
You can read more about that factor here in the wikipedia article on Gravitational Time Dilation where they use the Lorentz factor and the escape velocity to get the ##\sqrt{1 -\frac{ 2GM}{rc^2}}## factor.
https://en.wikipedia.org/wiki/Gravitational_time_dilation
Here is the LATEX for the factor of interest:
# # \sqrt{1 -\frac{ 2GM}{rc^2}} # #
NOTE: Remove the spaces between "# #" to activate the web page mathjax latex rendering code.
Please take some time to learn LATEX for entering equations here. The cut/paste of images just doesn't work out well. There is a link to LATEX formatting in my signature section at the bottom of this post.
You might call it the gravitational time dilation factor or the gravitational red shift factor. It doesn’t really have a name because it wasn't an independent discovery like the Lorentz factor, it's just a part of Schwarzschild's solution of Einstein's equations. It's also not particularly general because gravitational time dilation is only really applicable in some circumstances - it cannot be defined for things like a pair of orbiting black holes, for example
  • Love
Likes jedishrfu, IXWELL and dextercioby
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
