- 5,948
- 3,123
- TL;DR Summary
- Rather interesting video that shows that a 3-4-5 right triangle results when you draw lines connecting the corners to the midpoints of a square
It was a week or two ago that a friend of mine showed me a video of interest. The video is somewhat incomplete mathematically, but still is a good one. The author should state that when the product of the slopes of the two lines is minus one, (slopes are +2 and -1/2), that the lines are perpendicular.
In addition, using the ## \tan(\theta-\phi) ## identity, it is easy to show that the triangle is a 3-4-5 because the tangent of the apex angle, (slopes of +2 and -2 for the lines forming the angle), is computed to be 4/3. For the hypotenuse to be 5, the square needs to have sides of 2 root 5, which the author also omits.
I worked it a little further and computed the radius of a circle that is inscribed in a (right) 3-4-5 triangle. I found somewhat surprisingly that it has a radius of one unit. Following that, I was also able to show that the center of the circle coincides with the center of the square, so that all four 3-4-5 triangles have the same inscribed circle.
See
I see the video didn't load, but you may be able to follow the discussion, even without the video.
See
