Grade 11 Sound Intensity Question
To achieve a sound intensity one hundred times greater than 90dB, a sound level of 110dB is required. For the second part, determining how close Phrank needs to stand for the intensity to be at 60dB involves using the formula β2 - β1 = 10 log (I2/I1), leading to a calculated distance of 100,000m. The discussion emphasizes the need for clear calculations and encourages posting new questions separately for better clarity. Participants are urged to provide detailed workings for verification.
Zarquad
If Phrank's new speakers produce a sound of 90dB at 10m,
a) How many decibels would be required for the sound to be one hundred times the intensity?
b) How close would Phrank need to stand for the intensity to be at 60dB?
β2 - β1 = 10 log (I2/I1), where I2/I1 is equal to r1^2/r2^2
I got 110dB for the first question and 100000m for the second. I'd just like someone to verify my answers. I'm not very confident on the second.
For both I just used the formula. For the second I used these values:
β2 = 60
β1 = 90
r1 = 10
Another one:
You are observing a little light that emits a beep and a flash at the same time. You move backwards until the moment before you no longer hear the beep. You measure the beep to be at a frequency of 512Hz with a wavelength of 0.66m, and the time between the flash of the light and you hearing the sound is 3s. How close do you need to be to the contraption to hear the sound at 30dB?
d = vt
v = fλ
I think that's it.
I got 32m. I used the v=fλ to find the speed, which I then put into d=vt to find the distance at which you can't hear the beep anymore. Then I put that in the first equation and solved for r2 using these values:
r1 = What I got from d=vt
β1 = 0
β2 = 30
Please actually try to solve both of the questions I posted instead of just posting "makes sense to me" or something.
Agree with 110dB. Pls post your working for the second part.
Pls put new questions on separate threads.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
