Graphs of RC Circuit Responses
  • Thread starter Thread starter stunner5000pt
Integration of the area under a current-time graph in an RC circuit yields total charge in coulombs, confirming that current represents the flow of charge. The area under a voltage-time graph results in units of magnetic flux (volt-seconds), but its relevance in the context of an RC circuit is less clear. The relationship between current and voltage is defined by capacitance, linking charge and voltage. While dimensional analysis is useful, understanding the underlying equations is crucial for meaningful interpretations. Overall, the discussion emphasizes the importance of integration in analyzing RC circuit behavior and the significance of units in electrical engineering.
stunner5000pt
What is the meaning of the area under an RC circuit's Current-Time & Voltage-Time graph while charging the Capacitor?
[tex] I = \frac{V}{R} \exp (\frac{-t}{RC} ) [/tex]
This isn't a homework question per se but I wanted to understand how integration can connect things.
If we integrated the area under the graph, would this give us the total charge to charge the capacitor?
My logic here is purely based on units - if we integrate current on a current-time graph, the units of the integral is Amp sec which is coulombs.
Another question is - what is the meaning of the area under the Voltage-Time graph represent? In this case, this would give us unit of magnetic flux (Volt sec) but is there any other meaning to this?
Thanks again for your help!
stunner5000pt said:
Homework Statement: What is the meaning of the area under an RC circuit's Current-Time & Voltage-Time graph while charging the Capacitor?
Relevant Equations: I = \frac{V}{R} \exp (\frac{-t}{RC} )
Yes. This is basically the definition of current; the flow of charge. ##Q=\int {i(t)} \, dt##, or ##\frac{dQ(t)}{dt} = i(t)##
The relationship between current and voltage is in the definition of capacitance. Like this:
##CV(t) = Q(t) = \int_0^t {i(\tau)} \, d\tau + Q(0)##. So the voltage is essentially a scaled version of the capacitor charge.
You could certainly integrate the voltage (or charge) over time, but it's not clear to me what value that has. Maybe in more complex circuits? It would certainly be a valuable operation if you had an inductor across the capacitor, then you would know the inductor current.
Dimensional analysis is a great tool for checking results or developing guesses. But you have to know the underlying relationships (equations) for it to make sense. For example is newton-meters torque, or work? You can't know from just the units.
Yes.
Yes, Volt⋅sec = weber. Another meaning is joule/amp =weber
But then why would you care about this in an RC circuit? It has a name, but does it mean anything in this system? Context matters.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
