Gravitational Acceleration-Orbital Motion
The discussion revolves around calculating the gravitational acceleration at a distance of 2 x 10^6 m from the surface of Planet V, given the weight of a 0.60 kg object is 20 N. Participants agree on using the formula F=ma and a=MG/r^2 for their calculations. The initial calculation yields an acceleration of 14.8 m/s^2, which does not match the provided answer options. There is a consensus that the question may contain an error, as multiple users arrive at the same result. The focus remains on verifying the calculations and addressing potential discrepancies in the question itself.
physgrl
The weight of a 0.60 kg object at the surface of Planet V is 20 N. The radius of the planet is 4 x 10^6 m. Find the gravitational acceleration at a distance of 2 x 10^6 m from the surface of this planet.
a. 8.9 m/s2
b. 11 m/s2
c. 13 m/s2
d. 18 m/s2
F=ma
a=MG/r^2
I did
acceleration at surface=20N/.6kg=33.33m/s^2
acceleration at surface=MG/r^2
MG=33.33m/s^2*(4x10^6)^2
acceleration at a distance=MG/(r+d)^2
a at a distance=(33.33m/s^2*(4x10^6)^2)/(2x10^6+4x10^6)^2
a=14.8m/s^2 which is not in the options
I can't see anything wrong with your method. I did exactly the same and got the same answer as you !
It will be interesting to see if there are any other responses to your posting.
I think you did it right and the question is wrong. Anyone else see an error?
I get 8.89...
The weight will be 8.89N
Settled! Answers wrong
It doesn't ask for the weight, it asks for the acceleration, which should be 14.8 like the OP calculated.
thanks :D
  • · Replies 23 ·
  • · Replies 66 ·
