Halliday Resnick Krane Chapter 2 Problem 30: Juggling Five Balls
To solve the juggling problem, it's essential to determine the time each ball is in the air, which is approximately 1.28 seconds for a height of two meters. The challenge arises when juggling multiple balls released at different times, complicating the calculation of touch events. A systematic approach involves counting the number of times each ball touches a hand per minute. Understanding the timing and sequence of each ball's release is crucial for accurate calculations. Overall, careful analysis of the juggling pattern will yield the total number of touch events.
vibha_ganji
A juggler juggles 5 balls with two hands. Each ball rises 2 meters above her hands. Approximately how many times per minute does each hand toss a ball?
y= y0 + vt + (at^2/2)
If each ball rises two meters, then the time is in the air is equal to around 1.28 seconds. After this, what am I supposed to do? I feel really stuck. If all of the balls are released at different times, how am I supposed to find the answer?
What will happen if you don't handle each of the other balls before you re-handle the first ball?
.. or start with, how many times a minute does a given ball touch a hand? How many touch events are there in total per minute?
Likes vibha_ganji
By counting?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
