Heat (radiation) without direct air transfer - greenhouse effect?
In summary, the greenhouse effect is the phenomenon whereby heat is transferred from the sun through the atmosphere, due to the window being closed. This effect has been named after the places in which it is most commonly observed - greenhouses.
wildetudor
Hi everyone
I realized that I had a mistaken belief about the meaning of the term greenhouse effect. I thought that it refers to the phenomenon whereby there is an exchange of heat due to light but without there being a direct air contact between the body being heated and the surrounding environment; specifically, the effect that you get when you are indoors on a sunny but cold day, and the air inside is getting heated due to the Sun's rays coming in through the window, despite the room becoming colder if any windows were actually opened to let air in.
So I thought that the term refers to the phenomenon both at a planetary scale (as in the greenhouse effect leading to rises in temperature on Earth) as well as at a smaller scale (rooms, houses etc). I now read that the greenhouse effect actually has to do specifically with greenhouse gases...
So what is the name of the effect that I described earlier (if there is even a name for it)?
Many thanks in advance :)
Science news on Phys.org
Greenhouse gases are the "window", and there is no (significant) exchange of air with the environment (=space).
Thermal radiation?
Likes 1 person
So sun shining through the closed windows is still a greenhouse effect (+heat transfer due to thermal radiation)? And the same phenomenon happens, at a planetary scale, with the sun rays as they encounter the greenhouses gases (as opposed to the closed window)?
The first effect seems to make sense to be called a greenhouse effect, as greenhouses are indeed places that only get heat from the sun through thermal radiation and not through air - but how does this analogy extend to the Sun+Earth? Is it the case that the ozone layer blocks out most of the air contact, leaving just radiation to get through to the Earth?
No. Air contact does not exist due to gravity - the atmosphere has a finite height. Carbon dioxide, water, ozone and some other molecules reduce the infrared radiation going to space, similar to the glass window.
Likes 1 person
Sorry, I'm still not clear: so the window blocks out air, not radiation. If the ozone layer reduces radiation (IR, as you say, rather than UV i.e. sun rays) rather than masses of air, then how is this effect similar to the "closed window" effect, so as to warrant both of them the same name, i.e. "greenhouse effect"?
The ozone layer, which is located high in the atmosphere, is important because it blocks most ultraviolet radiation coming from the sun. Some UV reaches the ground and causes folks to tan. If there were no ozone, lethal amounts of UV coming from the sun would make it very difficult for terrestrial life to exist on earth.
When the sun shines during the day, it heats up objects on the Earth's surface. When this heat re-radiates, such as at night, when the atmosphere is cooler, instead of it escaping through the atmosphere back into space, it is absorbed by greenhouse gases in the atmosphere and becomes 'trapped'. It is this gradual accumulation of heat, which would otherwise radiate back into space, which is thought to raise global temperatures.
Likes 1 person
The combination of greenhouse gases (ozone is just one of many) and the finite height of the atmosphere gives a greenhouse effect.
Likes 1 person
Thanks for your answers guys!
Related to Heat (radiation) without direct air transfer - greenhouse effect?
1. What is the greenhouse effect?
The greenhouse effect is a natural process where certain gases in the Earth's atmosphere, such as carbon dioxide, trap heat from the sun and prevent it from escaping into space. This causes the Earth's surface temperature to be higher than it would be without these gases, making the planet habitable for living organisms.
2. How does heat (radiation) without direct air transfer contribute to the greenhouse effect?
Heat (radiation) without direct air transfer, also known as infrared radiation, is emitted by the Earth's surface and trapped by the greenhouse gases in the atmosphere. This process helps to keep the Earth's surface warm and maintains the overall temperature of the planet.
3. What are the main greenhouse gases responsible for the greenhouse effect?
The main greenhouse gases responsible for the greenhouse effect are carbon dioxide, methane, water vapor, and nitrous oxide. These gases are naturally present in the Earth's atmosphere, but human activities such as burning fossil fuels and deforestation have significantly increased their levels, leading to an enhanced greenhouse effect.
4. How does the greenhouse effect impact the Earth's climate?
The greenhouse effect plays a crucial role in regulating the Earth's climate. Without it, the Earth's surface would be much colder, making it difficult for life to exist. However, an enhanced greenhouse effect caused by human activities is contributing to global warming, leading to changes in the Earth's climate such as rising sea levels, more frequent and severe natural disasters, and disruptions to ecosystems.
5. What can be done to reduce the greenhouse effect and its impacts?
To reduce the greenhouse effect and its impacts, we need to decrease the amount of greenhouse gases in the atmosphere. This can be achieved by reducing our carbon footprint through actions such as using renewable energy sources, reducing our consumption of fossil fuels, and implementing more sustainable practices in agriculture and land use. Additionally, preserving and restoring natural ecosystems can also help to absorb and store carbon dioxide from the atmosphere.
10K
