Heisenberg indeterminacy principle
The discussion centers on the Heisenberg indeterminacy principle and its application to an electron's position and speed. It highlights that no object can exceed the speed of light, which limits the uncertainty in speed to a maximum of 3 x 10^8 m/s. A calculation using the uncertainty relation ΔxΔp = h/4π suggests a minimum uncertainty in the position of an electron, but the initial result of 3.049 x 10^-59 meters raises concerns about accuracy. A participant introduces a relativistic version of the uncertainty principle, proposing that as speed approaches light, the minimum uncertainty in position could theoretically be zero. The conversation emphasizes the complexities and nuances of applying quantum mechanics principles in relativistic contexts.
penmanta0711
No object can travel faster than the speed of light, so it
would appear evident that the uncertainty in the speed of
any object is at most 3 * 10^8 m s
(a) What is the minimum uncertainty in the position
of an electron, given that we know nothing about
its speed except that it is slower than the speed of
light?
Known
(Δx)(Δp)=h/4∏ hence Δx=h/4∏(mass of e-)(velocity)
Mass of e-=9.10x10^-31 kg
Velocity is equal to 3x10^8 m s
I plug in my values and came up with 3.049 x10^-59meters
My answer seems a bit wonky..could you double check..and if wrong give me hints to solve properly...thank you
There is a relativistic version of the uncertainty principle, ΔxΔv >= m2/(2* E3) where we are using units such that c = h-bar = 1. E = √p2+m2. where m is the rest mass and p is the relativistic momentum p = λmv. p can rise unbounded as v → c and thus so can E. Δv = c = 1, so Δx >= 0. The minimum uncertainty is 0. Or so I'd like to think.
