Help: How to Put Twisting Effect on Flash
  • Thread starter Thread starter ermines
    Flash
To create a twisting effect in Flash MX 2004, similar to the torsion of a rod, users can experiment with aligning small rectangles and applying a corkscrew effect, as seen in Swishmax. The challenge arises when trying to apply this effect to a cylindrical shape, as the twist is less visible on a 3D object compared to a flat plane. Solutions may involve manipulating the individual segments of the cylinder to enhance the visibility of the twist. Further experimentation with the layering and rotation of these segments could yield a more pronounced twisting motion.
ermines
Hello guys. I'm having trouble of how to produce a twisting effect/motion in flash mx 2004. The twisting I'm referring to is when you twist a rod at one end and the other end is fixed. It is like the concept of torsion.
So anyone have any ideas how to make this? An .fla perhaps?
Computer science news on Phys.org
umm guys, just experimented with swishmax. i saw this effect called corkscrew that smehows resembles a twisting effect. I just need to make very small rectangles and line them up to each added then add the effect to each one of them and each one of them slowly turns, creating a seemingly twisting effect. My only problem now is to apply it to a cylinder. The twist doesn't seem to be visible if it isn't a plane. So anyone have an idea?
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
