Help with definitions in linear algebra
devoured_elysium
Having a matrix, how can I know if the function the matrix is representing is:
a) Injective
b) Bijective
Thanks in advance
say the map is L:V-->W
it is injective iff for all w in W, there is at most one v in with with L(v)=w
it is bijective if it is injective and surjective.
These are the definitions. If you're having trouble applying them to a specific problem, you should tell us what the exact problem is and what you've attempted (if anything) and then we can help more.
Well, you could look at the definitions of those words! Any function, from one set to another is call "injective" if and only if f(x)= f(y) implies x= y: in other words, different members of the domain are mapped to different members of the range. That does NOT imply "surjective"- that something is mapped to every member of the range. For linear transformations, represented by a matrix, injective means that the domain space is mapped one-to-one to a subspace of the range space: that the rank of the matrix is equal to the dimension of the domain space, not necessairily the dimension of the range space.
In order to be "bijective" a mapping must be both injective and surjective: "one-to-one" and "onto". For a linear transformation represented by a matrix, that means it must be n by n for some positive integer n and have rank n.
Thanks by your replies
If I understood well, any matrix with non-zero determinant will be bijective, right?
I don't quite get what you mean by domain space and range space. I know what a vector space is. Is it related to it?
Thanks
If f:A-->B is a function, then A is called the domain and the subset f(A) of B is called the range. In the case where f is a linear map from one vector space to another, A is the domain space (or domain vector space) and f(A) is the range space.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
