How Can I Create a Flavored Coating for Ice Spheres in Cocktails?
  • Thread starter Thread starter AstroBar
    Liquid
To create a spherical coating of flavored liquid around an ice sphere, it's essential to freeze the liquid in spherical molds. The ice sphere should be sub-frozen to a temperature that allows the liquid to freeze upon contact, necessitating that the flavored liquid is also cooled close to its freezing point. Spraying the liquid onto a rotating ice sphere can help prevent melting from warmer liquid. Using a two-piece silicone mold can facilitate the process, allowing for easy DIY projects to hold the ice sphere in place while the outer shell freezes. This method can enhance cocktails by providing flavor and temperature regulation as the ice melts.
AstroBar
TL;DR
I am trying to figure out how to drop an ice sphere into an edible flavored liquid that directly solidifies into a perfect spherical coating over the ice. So that when it’s dropped into a cocktails it will slowly melt and give flavour and temperature regulation to the cocktail
Something like this - is what I’m among to do
Welcome, @AstroBar !
The easiest way is to freeze the edible flavored liquid in spherical molds.
For the way that you describe successfully work, the sphere of ice should be sub-frozen to a temperature low enough to force the liquid in contact with it to freeze, rather than melt the surface of the sphere.
Because of that, the edible flavored liquid (water-based mix, I assume) must be also cooled to near its freezing point, which is normally a lower temperature than for water.
Spraying the liquid over a rotating ice sphere should avoid heating the ice on a mass of warmer liquid.
Likes berkeman and DaveE
If you're going to do this repeatedly, maybe make a silicon mold to hold the ice sphere in place while you freeze the outer shell. Like a two piece hemispherical mold. Then a second step to fill in the support pedestal for the ice center. These molds are pretty easy DIY projects. There's lots of YouTube videos out there (many of which never seem to have heard of mold release; aka soap or oil film, if you don't want to buy the real stuff).
https://www.tapplastics.com/product_info/videos
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 30 ·
  • · Replies 42 ·
