How Can I Design a 13MHz Sine Wave Signal Generator with 30-40V Output?
Designing a 13MHz sine wave signal generator with a 30-40V output requires careful consideration of load characteristics, including impedance and current requirements. The discussion highlights the importance of matching the generator to the load to avoid output reduction and potential radiation issues. Common signal generators typically reach 20MHz but may not achieve the desired voltage without significant amplification. Suggestions include using a matching network and considering the use of MOSFETs to generate a square wave, which can then be filtered to create a sine wave. Overall, achieving the desired output may be complex for a hobbyist, making purchasing a ready-made solution a viable alternative.
TeeBeeBee
I am very new to circuit design so any help is much appreciated. I need to design a signal generator that will output about 30V-40V peak to peak at 13MHz (sine wave) If the signal generator is not able to, then I need some kind of amplifier. So far I have looked into Hartley and Colpitts oscilators and am not having any luck reaching my desired output. Any help or suggestions would really help. Thanks in advance
Is 13 MHz the only frequency the signal generator needs to produce?
What will the load be on the signal generator (how much current)?
Is the load strictly resistive or can it be capacitive or inductive?
Will the load be constant or variable and if variable by how much?
I would like to keep the frequency around 13MHz but if the output can be reached at lower/higher frequencies then the output takes priority. The load can be resistive, capacitive or inductive. The load is constant and I am not too sure about the current, but like to keep the current at a minimum though
Knowing how much current or better yet the impedance of the load is very important. If your load is connected by coax and the coax is more than about a meter and the load doesn't have the same impedance of the coax or the coax isn't the same as your signal generator, your output will be reduced. A VSWR meter can tell you if you are matched or not. If you aren't you can make of buy a matching network which you can adjust until you get a minimum reading on the VSWR meter.
Without seeing your circuit or knowing what your load is, I can't help you any more.
Will your signal be radiated? There are broadcast stations in the 12MHz frequencies, marine mobile around 13 MHz and radio astronomy above 13 MHz. A mismatch between generator and load as well as an improper ground can cause it to radiate. Recently two ham operators near Cleveland were fined $30,000 collectively for abusive radio transmissions.
Someone unskilled in the art is unlikely to fabricate such a generator cheaper than one can be purchased. Common signal generators reach 20 MHz, but are limited to about 20Vp-p when terminated into 50 ohms. It would require a 16 watt amplifier to barely achieve 40Vp-p into 50 ohms resistive, 32 watts for 25 ohms, and 8 watts into 100 ohms. So, knowing the load and being able to match to it is very important (see transmatch).
13.56 MHz is an ISM frequency reserved for equipment that might inadvertently radiate, so there is a convenient frequency nearby.
All of this is a bit much for a hobbyist to fabricate, but readily available to purchase.
A pair of mosfets, (as used in a switching power supply), would generate a square wave, that could then have a resonant tank circuit to remove the harmonics.
The OP specifies a sine wave. What level of harmonic content is acceptable?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
