How Can I Get This Pivot Point To Stay In One Point?
  • Thread starter Thread starter itsdonny
    Pivot Point
The discussion focuses on designing a joint that can flex while maintaining a neutral position at 45 degrees, using a spring mechanism. The goal is to achieve spring tension that allows movement but keeps the arm stable at the desired angle, potentially using a detent for added stability. Suggestions include using a clock-spring or torsion-spring for the spring-return feature and a ball plunger for centering. Damping options, such as rotary dampers, are also recommended to prevent excessive bouncing. The materials and dimensions of the components are crucial for ensuring functionality and stability in the design.
itsdonny
I'm trying to figure out a solution to this design. I want to add a spring to this joint so it can flex up and down and I want the neutral position to be at 45 degrees as pictured. So if you push it either way it springs back to this position. At the same time I dont' want the arm to bounce around so I want to make this 45 degree position sticky. Perhaps a detent could hold it in place until pushed beyond a certain tension.
So I'm looking for ideas as to how I can 1. add spring tension to the joint and 2. have a sticky point. Any ideas would be appreciated. Feel free to modify the drawing I made if you're feeling motivated. Or if you can think of some examples where something like this has been done, please let me know.
Thanks!
Oops, here's the image:
http://www.notesofrock.com/temp-images/hinge-ideas-02.jpg
I can think of a few methods, but you've left a lot to the imagination. What are the dimensions, materials, forces, ...?
Good point. : )
The body will by made of some type of plastic and will be about 6" long. The arm is made of fiberglass tube with an O.D. of about 5mm, and the length of the arm is about 16" with about 1 oz of weight on the end. The spring will of course need to be strong enough to elevate that throughout its range of motion. Thank you.
There are several ways to go -- a lot will depend on your budget. You also failed to mention if this is just something you're building for yourself or if it's destined for production.
The spring-return feature can be done with a simple clock-spring or torsion-spring. A ball plunger for the centering detent can also offer some damping function.
Damping can also be accomplished with commercially available rotary dampers, such as these:
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
