How can l prove that Newton's laws are time invariant?
The discussion centers on proving the time invariance of Newton's laws using mathematical expressions. A solution x(t) is presented, leading to the consideration of y(-t) and its relationship to x(-t). The key question raised is how the second derivative of x(-t) relates to the function f(x(-t)). Participants suggest using LaTeX for clarity in mathematical notation. The conversation emphasizes the need for precise mathematical formulation to demonstrate the invariance effectively.
stefano77
Misplaced Homework Thread -- Moved to the Schoolwork forums by the Mentors
how can l prove Newton's law is time invariant?
if x (t) is a solution of dd/ddx x(t) = f(x(t)) then if l put y(-t) dd/ddt y(t)=dd/ddt x(-t). Now how dd/ddt x(-t) is equal to f(x(-t))?dd/ddt is second derivative with respect to time
You've previously used LaTeX on this site. Can I suggest you repost the above using LaTeX? If you have forgotten the syntax there is a guide linked below the reply box. If the LaTeX does not render when you try to preview it, refresh the page while in preview and it should work (you may wish to copy your text to clipboard first as a safety measure).
Likes topsquark and vanhees71
if x (t) is a solution of dd/ddx x(t) = f(x(t)) then if l put y(-t) such that dd/ddt y(t)=dd/ddt x(-t). Now how dd/ddt x(-t) is equal to f(x(-t))?dd/ddt is second derivative with respect to time
##\dfrac{d^2}{dt^2} y(-t) = \dfrac{d^2}{dt^2} x(t)##
or equivalently
##\dfrac{d^2}{d(-t)^2} y(t) = \dfrac{d^2}{d(-t)^2} x(-t)##
Can you finish?
-Dan
Addendum: Please note my addition of "such that" to your original post. You needed something to separate those two expressions.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
