- #246
vanesch
Staff Emeritus
- 20
RandallB said:Non-Local viable theories discussed here competing to be THE solution include:
1) GR
2) MWI-QM (Strings included)
3) OQM
4) QFT
5) BM
All are non-local, and basically in competition with each other, with General Relativity having the widest differences with and all the others.
Uh ?
GR and MWI-QM (including QFT when seen that way) are strictly local (and deterministic), in the sense that the deterministic dynamical changes to the state are entirely determined by the local part of the state itself. This is somewhat harder to see in MWI-QM than in GR, where it is obvious, but one can reformulate MWI-QM in ways where this is explicit.
OQM doesn't (by definition) prescribe any underlying mechanism, so the above definition of locality doesn't apply, since OQM is just an algorithm to predict probabilities of things happening in a classically described world.
So we can only look at OQM's probabilistic PREDICTIONS, and then we have to say that OQM's probability predictions do not fit with Bell locality, but respect signal locality.
BM, in the sense that it proposes more than OQM, namely an underlying (and moreover deterministic) mechanism, is non-local in its inner workings.
That's not a "shortcoming" wrt OQM, which bluntly doesn't propose any underlying mechanism.
Essentially not being able to do it with SR is what put Einstein on the path of GR.
I hope you realize that SR and GR are the same, if you switch off gravity ?
GR is a non-local option (background independent) to complete that picture, so naturally in principle it competes with other non-local options to be the complete solution. But does anyone feel their preferred non-local theory needs to reject the basic principals in SR?
GR is background independent, not because any non-locality, but because of general covariance: the fact that any description will do, and that a priori, nothing in GR prefers any description over any other.
You can reformulate SR also in a completely background independent way, without making use of any reference to an "inertial frame".
It's pretty easy: call 4 variables, "coordinates of events", and associate a metric tensor to each of the set of 4 values of coordinates. This metric describes entirely locally, the relative distances of events. It is empirically measureable. If the Riemann tensor that derives from it is identically 0, you have a correct SR description.
