How Do Point Charges Affect Force on a Charge Along the X-axis?
The discussion focuses on calculating the total force exerted on a third charge, q_3, by two point charges, q_1 and q_2, located on the x-axis. The user has set up the equations for the forces F_1 and F_2 using the formula for electric force, but is unsure of their calculations. Another participant emphasizes the need to show detailed calculations to identify any errors. The user is seeking guidance to correct their approach. Accurate calculations are essential for determining the correct total force along the x-axis.
wingit132
Two point charges are located on the x axis: one charge q_1 = -15.0nC located at x_1 = -1.745m , and a second charge q_2 = 38.5nC at the origin.What is the total force along the x axis, including sign, exerted by these two charges on a third charge q_3 = 47.0nC placed between q_1 and q_2 at x_3 = -1.160m ? Use 8.85*10^-12 C^2/N*m^2 for the permittivity of free space.
I have set up the equations F_1 =q_1*q_3/4pi*e_0*r_1^2 and F_2 =q_2*q_3/4pi*e_0*r_2^2
q_1=-1.5*10^-8C
q_2=3.85*10^8C
q_3=4.7*10^8C
r_1=.585m
r_2=1.160m
It tells my I have the wrong answer but I just need a push in the right direction.
Thanks
Hi wingit, welcome to PF.
Please show your calculations. Unless we see your calculations, we are not in a position to
say where you went wrong.
