How Does a Bead Behave on a Rotating Hoop?
  • Thread starter Thread starter VRCAM
    Bead Mechanics
The discussion focuses on the dynamics of a bead sliding on a rotating hoop in a vertical plane. The kinetic energy is derived as 1/2 * m * a^2 * (ω^2 * sin^2(θ) + θ̇^2), while the potential energy is given by m * g * a * (1 - cos(θ)). The equation of motion for the bead is established as θ̈ = (ω^2 * cos(θ) - g/a) * sin(θ). It is concluded that for ω²a < g, the bead can achieve stable equilibrium at the bottom of the hoop, while for ω²a > g, a new equilibrium position θ* is found, leading to oscillations characterized by angular frequency Ω. The discussion emphasizes the importance of analyzing equilibrium points and their stability in the context of the bead's motion.
VRCAM
Consider a bead of mass m that can slide freely on a circular hoop of radius a which lies in a vertical plane. The hoop rotates about a vertical axis through its centre at fixed angular velocity \omega. The angle \theta is the polar angle of the bead measured from the downward vertical.
1. Find the kinetic and potential energy of the bead.
2. Find the bead's equation of motion.
3. Show that for \omega^{2}a &lt; g the bead can remain in a stable equilibrium at the bottom of the hoop, otherwise this position is unstable.
4. In the case \omega^{2}a &gt; g find the new position \theta^{*} of stable equilibrium and calculate the angular frequancy \Omega of small oscillations about this position.
I worked out the answers for the first 2 questions myself (see below)
1. The kinetic energy is \stackrel{1}{2}ma^{2}(\omega^{2}sin^{2}(\theta)+ \stackrel{.}{\theta}^{2})
The potential energy is mga(1-cos(\theta))
The above are just from the geometry of the situation
2. The equation of motion of the bead is \stackrel{..}{\theta} = (\omega^{2}cos(\theta) - g/a)sin(\theta)
This just comes from using the Lagrangian L=T+V and treating it as a function of \theta and \stackrel{.}{\theta}
3 and 4. This is where I am getting stuck! When I set to zero dv/d\theta I get mgasin(\theta)=0 which does not relate to \omega! Would it be necessary to use minimise an effective potential instead? I've tried this but the algebra is not going anywhere and a little insight would be helpful.
I don't think your kinetic energy is right. You should have three terms since the kinetic energy ought to be 1/2*m*v.v, where v velocity of the bead.
I agree with his Kinetic energy expression - the velocities are confined to different planes- this should mean the dot product between is zero. Or have I screwed my geometry up there something rotten?
The KE is correct. It's the sum of two orthogonal velocities, the part along the hoop and the part related to the rotation of the hoop.
As for the rest of the problem, you can think of the right side of the theta eom as a 'force'. The equiibrium points are where it vanishes. Take the theta=0 point, if you expand to first order in theta, you get
<br /> \stackrel{..}{\theta} = (\omega^{2} - g/a) \theta<br />
Now you can see that if the factor in front of the theta is positive, then if theta moves away from zero it will keep accelerating away. If it's negative, it will accelerate back. It must be obvious where the other equilibrium point is, right? Play the same game there and write an expansion in terms of dtheta, where dtheta is the difference from equilibrium. To get the oscillation frequency, notice these expansions look like harmonic oscillators.
Yes, sorry. I read the question wrong!
