How Does Changing Mass and Speed Affect Spring Compression?
The discussion centers on the effects of changing mass and speed on spring compression during a collision. When a block of mass m and speed v compresses a spring by a distance deltaX, halving the mass and doubling the speed alters the energy dynamics. Applying conservation of energy principles can help determine the new compression distance. The kinetic energy of the block before the collision can be equated to the potential energy stored in the spring at maximum compression. Understanding these relationships is crucial for solving the problem effectively.
bcalkins
Question: A block of mass m and speed v collides with a spring, compressing it a distance deltaX. What is the compression of the spring if the mass of the block is halved and its speed is doubled?
I have no idea how to do this problem. If anyone can explain this to me it would be GREATLY appreciated. Thank you!
Have you attempted to use conservation of energy principles?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
