How Does Earthing Affect Charge Distribution on Spherical Shells?
In summary, the conversation discusses charge distribution and how it applies to three concentric spherical shells with different charges. The inner surface of shell B must have a charge -q, while the outer surface has a charge q' and the inner surface of shell C has a charge -q'. The charge conservation rule does not hold for shell B because it is connected to ground, but it does hold for shells A and C as they are isolated. The conversation also touches on the concept of a cavity within a conductive shell and how charges inside can affect the field both inside and outside of the shell.
  • #36
gneill said:
I can't tell you why it's needed since you haven't presented the rest of the context in which that diagram found.
Only this much information has been given.Figure (2) and charge distribution has been given as a hint.
  • #38
Thread re-opened.
  • #39
DaleSpam said:
Closed pending moderation.
I wonder why?
  • #40
ehild said:
I wonder why?
There was some concern that the thread was being spread into other threads with the conversations and results crossing each other. This makes following anyone thread a tad confusing, and moderating the ensemble somewhat problematic. Merging the threads was discussed, but it was decided that it would not give a satisfactory or more elegant result. So for now the thread is re-opened and any new fragmentation will be discouraged.
  • #41
From the OP:
Figure (1)shows three concentric thin spherical shells A,B and C of radii a,b and c respectively.
The shells are thin, but still they have inner and outer surfaces. The shell makes a wall that surrounds the enclosed cavity. There is no charge, and the electric field is zero inside the wall, but there can be surface charge on both surfaces. The following is better for Fig. 2 as it was in the OP as it indicates that the charges belong to the surfaces.
Shell B was not given any charge, but it is grounded, the shell can have nonzero net charge.
Likes gracy
  • #42
Thank you gneill, for the explanation, and also for re-opening the thread.
Likes gracy
  • #43
But it is not compulsory that every earthed shell would have some non zero net charge.Why surface of shell B contain charges,what if the charges are not there?
  • #44
A single earthed shell is not charged, but B encloses a charged shell, and is surrounded by an other charged shell. If you derive the potential of all shells, you get how much charge B must have to be at zero potential.
  • #45
But I was not told to find potentials so I did not consider it ,I believe that's why I got stuck.
Does it mean whenever I will find such problem when there is not single earthed shell ,I'll assume some charge on it's surface later with the help of potentials ,I will find how much charge B must have to be at zero potential?
Right?
  • #46
What if the problem does not mention "thin",solution would be same?
  • #47
The problem asked you
Find the charge appearing on the surfaces of B and C.
, which means you need q' in terms of q. You should have figured out how to do it. You have to know, how to get the electric field of charged shells and potential difference between them, and how to get the potential of the outer shell C. Deriving the expresion for the potentials of the shells, you get an equation for q' in terms of q.
gracy said:
Does it mean whenever I will find such problem when there is not single earthed shell ,I'll assume some charge on it's surface later with the help of potential ,I will find how much charge B must have to be at zero potential?
Right?
Right. If a charged body is near an earthed conductor, the conductor gets charge from the earth.
Likes gracy
  • #48
Thin means the thickness of the shell is small with respect to the radius, so we can speak about "the radius of the shell". If they were not thin, the inner and outer surfaces would have different radii. Those radii should be given, and the solution would be different.
Likes gracy
  • #49
Will it be a problem?
  • #50
No problem, but you need to take them into account when calculating the potential of the shell.
Likes gracy
  • #51
gracy said:
r.Hence,charges migrate from cavity but field stays.
But according to the following video
charge +q stays in the metal cavity .
How do we know that outer surface of B would have positiv charge i.ewhy not we assumed -q' instead of q'?
  • #52
gracy said:
How do we know that outer surface of B would have positive charge i.e.why not we assumed -q' instead of q'?
I believe it is because the net field inside the thickness of shell B must be 0 since it is a metal.
  • #53
The video itself explains why very clearly. What does the video say?
  • #54
It is not from the video.It is fro my OP.
  • #55
Then why did you bring in the video at all? Honestly gracy, that is irritating.
Thread closed. Please spend more time on your own before posting and then put some additional effort into making clear and focused threads.
